Brake Fluid Change?
Bluemustang
2015 Mustang Base GT
For a purely street driven car you're good for now. I'd flush and change when you feel the pedal more spongy. Every 2 years at least I'd say. It is mileage, abuse and time based so it depends. Synthetic based track focused fluids you should change more often.
Charlemagne
Czech Republic (Europe)
Nick
Some brake fluids with higher boiling points have 3 year change interval, like ATE TYP200. Ford uses pretty good Motorcraft fluid with 338 °F (170 °C) wet boiling point and 509 °F (265 °C) dry boiling point, and if they say it has 3 year change interval in the manual, there's no reason to doubt them for street use.
ATE TYP200 has 388 °F (198 °C) wet boiling point and 536 °F (280 °C) dry boiling point, even better than Motorcraft then, ATE says it has 3 year change interval. It's my go-to brake fluid in my other cars. That is for street use, track use requires much more frequent changes.
For example favourite Motul RBF 600 has only bit better boiling points - 401 °F (205 °C) wet and 594 °F (312 °C) dry. But it has recommended change interval 1 year, it absorbs water faster. It's intended for track use with more frequent changes.
