BlownOne
Horsepower Fiend
- Apr 14, 2017
- Sacramento, Ca
- Anything with wheels
Good info brotha!Timing tapers off up top because you're making more boost up top. More boost means less timing usually governed by octane. The tune will also lower timing according to load which can be adjusted in the tune.
If you're on e85 and methanol, even with 17psi I would expect more than 16* up top. I would talk to your tuner to see if it can take more timing. Like I said, the tune may be limited to how much timing it will add with the knock sensors based on boost/load. I've read boosted E85 coyotes can do 22*+, depending on boost level of course. It's possible that you've reached the limit of timing at 17psi but only your tuner could tell you.
That being said, at a certain point you will reach the maximum timing that makes more power, after that you're just putting stress on the engine for no gain. I'm not sure what that is for our motors though.
Here's my stats with my last nozzle. Knock reading wont really matter since timing is telling you what the knock sensors are doing. But it will tell how much timing is commanded in the tune versus how much is being added with the sensors.
Year: 17 GT
Fuel: 93 with 60/40 meth/water 625 ml/min Snow nozzle
Max Boost: 13.5psi
Total timing: 18* at the hit, climbed to 22*, tapered to 21*
Knock: -1.25* Knock on the hit and -3.89* knock up top
Ambient Air temp: Dont remember
Iat: 28* starting 54* ending iat swing during 3rd gear pull from 2500-7400rpm
That’s what I thought about timing tapering as boost increases too, but even with just e85 (meth isn’t doing anything above 5k rpm) I would think timing should be higher up top. It looks like it holds great timing at first when the meth is hitting then goes back to how it’s been once the r’s start climbing. I’ll be able to test my therapy after I install the new nozzle and if timing pops up in the 19* area that will be perfect. If not then it’s something limiting in my street tune, which has less timing commanded, but has the ability to add enough to bring it to 19-20*.
Another variable is horsepower level since a motor making 600hp would have less cylinder pressure and should want more timing than a 1000hp motor, all other things being equal. Guess I would need timing info from more guys making 1k+ horsepower to confirm tho.
I’ve talked to Jon@Lund about it already and he’s saying that the car is just happy with that timing and doesn’t seem to want more, which he said from the start when we were initially tuning. I have a race file that commands more but I’m waiting to test it after in get the 1200ml nozzle in and see what timing does on the street file.
Damn bro the meth must be soaking the iat sensor to get you down to 28* lol.
