BBQ tick :(
CJJon
Port Orchard
2020 Mustang GT/CS Convertible - Race Red
It could be something as simple as assembly lube that gets in the oil. I believe it is oil cavitation that is the cause and assembly lube could vary the oil properties enough similar to what Ceratec does.
Do I think it can cause damage? Certainly...if it is happening in a critical area, which I do not think it is.
bammons88
bammons88
Ben
2020 GT
I didn't start this thread to beat a dead horse. The tick is what it is, if I have to drop some friction modifier in every 5k miles then so be it. I'm not worried about catastrophic engine failure etc..just wasn't expecting it after 3800 tick free miles..like I said it goes Saturday to get the LTHs installed, at that point whatever ticks or rattles are present should be a thing of the past, bc I won't hear them over the exhaust lol.
Bikeman315
Myrtle Beach, SC
Ira
It directly did for me - did _not_ have it before - first noticed it the evening after my first oil change (wasn't looking for it - could hear it reverberating off the wall of the drive-through).
Why on earth are there so many people here insistent that the _many many many_ accounts of developing the tick after the first oil change are just "wrong". I don't get it.
No one said you were wrong, at least not me. Reports of the tick go back 4 years with the introduction of the Gen 3 motor. After a period of time we started getting reports that the tick started after an oil change. Sometimes the first, sometimes the second.
That said we do not have any proof there is a correlation between oil changes and the tick. Hell, we do not even know what the darn tick is much less when and where it starts.
By the way the reason I sent you that earlier thread is that there are a # of posted videos with the tick. I thought it might be helpful.
Bikeman315
Myrtle Beach, SC
Ira
You had the best intentions Ben, but this topic hits a lot of folks buttons in a very bad way. At least you have accepted it and will be willing to try and reduce it. Good luck with the LTH's.
EDIT: By the way as I mentioned before, I had my original oil tested. Nothing extra was added to it.
Bikeman315
Myrtle Beach, SC
Ira
The tick starts back after an oil change. It goes away after oil ages. My car does not tick(old oil) and I am about to change oil. It will be back. Fourth oil change now. Has done it every time. Goes away and comes back.
The tick has been around since the coyote was introduced. It IS a characteristic of the engine and is normal. The gen 3 for various reasons amplifies it. That’s the end of this story.
:like: Right up to the next time someone posts about the tick.
IronG
2019 Mustang GT PP2
Hmmmmmm BBQ, can't wait to get me some....not sure I have ever had BBQ ticks though....guess they would fine be fine with some bacon!
Matthewstorm
NC
Matthew
2021 Mustang GT Premium
For those of you that added Moly, do you add on top of 10 quarts of oil (for the Supercharged engines)?
3rdRGR
Indiana
Rick
2018 Roush RS2, 2025 Acura RDX
but I still do not buy into the idea that the tick appears immediately after the first oil change nor that a certain friction modifier makes it disappear.
A certain friction modifier does indeed make it disappear and the amount of data saying it does is very large. I am part of that data. It was night and day and quite immediate. If the tick bothers you, there is a fix (to be clear from HEARING it) and the data that says it will cause you a problem are I believe to date non-existent. If I'm incorrect, I'm open to correction. I know what is "advised" and I know what "can" be voided. I've yet to hear of one instance where it bit a Ceratec user.
Modulom4
Montreal, Canada
Pascal
Mustang GT 2018 PP1, Ford Edge 2008 SEL
The paper says MC 5w-20 so I'm assuming blend since it was only listed as $4.97/qt
full synthetic 5w30 or 5w-50 you will be fine, no more tick
3rdRGR
Indiana
Rick
Not in the US. Europe may have a different recommendation but not sure.
