not the bbq tick
Wsvi
Rock Hill South Carolina
Ed
2019 Mustang GT
2019 Gt has a tick that is constant at idle , when the rpms are up like during a cold start i dont hear it ,but as soon as it idles down it starts. The sound comes from the passenger side valve cover, the insulator for the hp fuel pump is missing but this tick is loud so i dont know if its that ,other than that the car runs fine .
Wsvi
Wsvi
Ed
2019 Mustang GT
nobody else with this problem ?
i found a thread that had the same problem from a couple if years ago but there wasn't anything about what caused the tick
Balr14
SE Wisconsin
BMW Z4 M40i
Modern engines with direct injection and extensive use of aluminum and plastic make a lot of noise. These materials have poor noise absorbing properties, so there will always be higher pitched harmonic sounds. Plus, direct injectors are very noisy.
From what I have observed, moderately loud ticking sounds that occur at idle, but disappear as rpms increase, are caused by injectors. I have observed this on multiple cars, not just Mustangs. But, the V8 configuration and firing order has a different cadence than other configurations. So, residual sounds will be different.
I am hearing impaired, which gives me some advantages, believe it or not. You hear all the sounds around you, I don't. I only hear what my hearing aids allow me to hear. I can hone in on higher pitched sounds and adjust the volume and range.
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
I don't know what to tell you. These engines are noisy (as are most modern engines), my car is new and makes all kinds of noises at idle (its 8 cylinder, 32 valves, 16 injectors, and tons of other stuff working in harmony). Doesn't bother me one bit. Send her to redline and forget about it. Noises you want to look out for are rod knock, grinding, high pitched noises. As well as monitoring oil levels, color, smoke, etc. If you are too concerned take in for warranty work if you are still under warranty. At least a video of the sound would help, don't think many people can help here.
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
Direct injection, cam phasers, timing chain, injectors or maybe 1 of 100 other things that make the coyote noisy. As long as it's ticking it's probably running strong. If the engine gets quiet you better start to worry.
LOL Exactly. Ill stick to my slogan "If my Coyote don't tick, I don't want it"
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
