Battery?
The Rooster
earth
2017 GT350
Quick question... the battery in my 350 is toast. Just pulled it out and was surprised to see that it’s only 470cca. It’s a motorcraft battery so I figured it was the original... just seems small. Is the right size?
pilotgore
US
A bunch
Looking at some older posts, it looks like many reported only 390CCA as the stock battery, but I’m unsure of the year of those cars.
RareBreed
Ohio
Brian
2019 GT350R, 2018 Challenger Hellcat Widebody M6, 2018 F-150 Raptor, 2003 Corvette, 1998 Mustang Cobra
I have a 2019. Factory battery had a black label and was 390 cca. Motorcraft replacement has red label and 470 cca.
lenFeb
USofA
Len
2019 Shelby GT350 #K0110
Same here. '19 with 390 CCA original battery. The MC 470 CCA with the red label is most likely dealer replacement,
s2ms
Seattle
1966 GT350 - 6S1757, 2017 GT350 - H3303
The OE battery listed in the 2017 GT350 supplement manual is a BXT-99RT4-A, 470 cca, so sounds like yours is the original. My 2017 has a BXT-96R-590 (590 cca) which was in the car when I bought it new. Fits and works fine. I assume there was a problem with the original and the dealer swapped in the 590, which oddly is the stock battery for the regular Mustangs.
The Rooster
The Rooster
earth
2017 GT350
Thanks fellas. I’ll just get the 470 from the dealer. Or the 590 if they don’t have it. Assuming it’s a little heavier but I don’t think that’s much of a concern
dirtwarrior
kentucky
Joe
2015 3.7 mustang
When my battery goes I will get a larger battery. With minor mods what group battery fits?
72&18
Kansas City
Doug
72 Mach 1, 72 F250 2wd, 18 GT350, 22 Bronco 2 Door
Costco has Interstate 96R for our Shelby's. $100.
FreePenguin
Ohio
Donald
17 mustang
Do you know if the battery tray is bigger on 350 vs gt or eb? I may also grab the 570 if it’s available
The Rooster
The Rooster
earth
2017 GT350
Im guessing its the same tray as the gt. theres room for a bigger battery but Im inclined to stick with the stock one.
Caballus
Europe
GT350
Went through the same thing with my 2016, as did several other members here. According to FP, the GT350 got the smaller batteries to save weight (I believe it was to save money when they were trying to keep the 2015/16s under $50k, but that's me). This was unique to the GT350. Not having the foresight to use a battery tender early on, many of us saw our batteries fail within the first year or two. Many among us replaced them with the standard Mustang battery, rather than returning to the 390. Having learned the hard way, and having the battery tender from the 2016, the 2019 immediately got hooked up to the battery tender.
Lesson: 1) use a tender, 2) when time to replace, use a more robust battery, unless trying to save weight for track purposes.
A quick search will turn up the multiple threads from the past. Good luck.
The Rooster
The Rooster
earth
2017 GT350
Ended up getting the stock replacement bxt99. On the tender now waiting for warmer weather...
