Battery tender needed for First SCT flash?
Schwerin
Home
2019 Mustang
Last time I did an SCT it was 2005 and it just took like 5 minutes.
How long does a first ECU backup/reflash take now? Should I put the car on a battery tender while its processing?
JTM88
Tulsa, OK
Jason
'20 Mustang GT ESS G3/G4 PP1
I used a 10a battery charger when I did mine. It may not be necessary, but its cheap insurance IMO.
Schwerin
Home
2019 Mustang
If your car can't be in accessory mode for ten minutes you have bigger issues
Well I haven't seen anything exactly how long the backup and reflash takes, hence my question. Any video on it jump cuts or fast forwards instead of telling you the actual time needed.
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
I usually throw the tender on mine while I flash. Might not be necessary but Id rather be safe than sorry.
SBR70.3
Edmond, OK
2021 Mach 1, 2016 Mustang GT Premium, 2023 Explorer ST, 2019 GTI (DD)
Speaking from experience, I would suggest a battery tender. This is regarding my GTI, not my Mustangs, but the situation could occur.
I frequently change from a stage 1 to stage 2 map when I take my GTI to the track. No issues there and the flash takes maybe 2-3 minutes. I recently bought an E85 tune. That flash took longer than I expected. Long story short, my ECU was bricked. I had to send the ECU and my Cobb Accessport to Cobb for repair. Only cost was shipping, but still it was a pain in the ass to deal with.
TXGTPig
United States
Danny
So I just went through the tuning process from scratch. In all total, I'd say it was about a 25-30 minute ordeal. I kept mine on a tender.
JTM88
Tulsa, OK
Jason
Had a similar experience with my GTI. I didn’t have the battery charger clamp secured properly, and the battery nearly died right at the end of a tuning .
That car burned through a battery almost every year like clockwork so I always used a charger when tuning.
robvas
MI
2011 GT
In my experience the SCT is good at saying "you don't have enough juice" and won't try to flash
GTyosh
Jay
21 Mach 1
You should ALWAYS have a battery tender for any and all flashes. You risk bricking the pcm if you don't.
K Myers
Ft myers Fl
Maurice
2015 GT Mustang
If your battery is weak yes, but it won't hurt
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Never used one, as flashes take ~5-10 minutes, but if the battery is getting old its not a bad idea.
Robottrainer
Canada
2018 Ford Escape. 2020 Jeep Cherokee. 2021 Ford Mustang GT Stage 2 Roush
Flashing is a huge battery drain. Hook up a charger or you risk bricking the pcm if the battery dies
