Battery Charging without AC power access
JohnK
Seattle (Bothell), WA
2015 GT PP Ruby Red
We have moved to a condo where I don't have access to AC power from my parking spot. I've wondered if anyone makes a rechargeable power bank with a trickle charger. After trickle charging for a time, the device could be removed, charged, then moved back to the car to continue trickle charging the batter. Has anyone heard of such a device? I got the idea when I saw a power bank emergency starter in Costco the other day.
Rollin'
Pa
17 gt pp
Hi John, I don’t know of any trickle chargers like you describe but have you considered a solar powered one? I never used one so I don’t know how well they work. Hope you find your solution. Cheers
Bikeman315
Myrtle Beach, SC
Ira
JohnK
2015 GT PP Ruby Red
Bikeman315
Myrtle Beach, SC
Ira
Bikeman315
Myrtle Beach, SC
Ira
Vlad Soare
Bucharest, Romania
Vlad
2020 Mustang GT 6MT
Maybe a UPS then?
A trickle charger, given a battery that's already fully charged, shouldn't draw too much power just to maintain it. A UPS may be able to support that for quite a while.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Take the battery out of the car and bring it inside.
Dana Pants
Burlington MA
Dana
2018 GT PP1
By far the easiest thing is to start the car for 15 min ever month or bring the battery inside. The nuclear option is to get a M18 power pack and a 5A battery charger and bring it to the car every few weeks for a battery boost.
boB
boB
2019 GT PP1
#1 - get a 2nd battery (preferably deep-cycle)
#2 - make a wiring harness with a Y and two diodes to isolate the batteries when both are temporarily connected to the car
#3 - connect battery 1 to the car through the diode harness
#4 - after 2 weeks connect battery #2 (just charged) and disconnect battery #1 - charge battery #1
repeat #4
* do not open the door of the car or the fuel pump, etc. may start causing extra battery drain
* 10 amp diodes should be ok
JohnK
2015 GT PP Ruby Red
Maybe a UPS then?
The UPS seems like a great solution. I need to figure out how much capacity I would need. I have a friend who is an EE and I'll ask his help in selecting one. Thanks! - John
JohnK
2015 GT PP Ruby Red
Well, I haven't found any viable solutions, so I am down to removing the battery for the winter. Is it better to keep it charged while it is being stored, or is it OK to leave it stored without charging and charge it in the spring when I want to start driving again? Thanks to all for your suggestions.
Vlad Soare
Bucharest, Romania
Vlad
2020 Mustang GT 6MT
It's better to store it charged. Lead acid batteries don't like being in a low state of charge for a long time.
But you don't have to stress over it. Just charge it fully, then store it, and in spring you can top it up if necessary. If it's disconnected it won't lose enough charge over the winter to cause you to lose sleep over it (provided it's healthy, that is).
