Automatic Shift Knob Swap
Dirtyblueshirt
Award Winning Taste™
Anaheim, CA
Aaron
2022 Ford Ranger Lariat Tremor
So... You bought an auto... And want to put a manual shift knob on it...
Because there are so many options for manual shift knobs, and a lot of people like the look and/or rest their hand there often enough to want to try something different.
Sent from my iPad using Fingers
Boff
The Motor City, eh?
2015 GT PP 401a Race Red
Scans as...
Well, I'm not dumb but I can't understand
Why she walk like a woman and talk like a man
Oh my Lola, lo lo lo lo Lola, lo lo lo lo Lola
That being said, having got this far, it is possible for the poster to get any of the hundreds of MT knob options that don't have a shift pattern on them.
DJ Red Barron
West Monroe, LA
Barron
2016 Dodge Challenger Hellcat / 1986 Buick GN
Sub'd as well.
jasonstang
Denver, CO
2017 GB GT/CS 6MT
I wonder if its possible to add toggle buttons on the shift knob so I can shift from both behind the steering wheel and on the shift knob?
Dirtyblueshirt
Anaheim, CA
Aaron
In theory, yes. You should be able to figure out the signals from the switch, and pair that to the corresponding wires in the steering column behind the clockspring.
Blk2015GT
2015 GT
Why replace the stock 6spd knob then either? Options- shape and color
Nothing wrong with an auto with a blank ball on it. I agree dont pretend it's a manual with a 6spd pattern on it though, but Im pretty sure that was just a test fit with parts lying around type of thing,
Blk2015GT
2015 GT
I just ordered a kit from sickspeed. Its a metal collar that is held in place with a set screw. Then a larger metal shaft that slides over that and is spring loaded. You screw any knob to the top of that
So in theory this attaches to the post of the shifter with a set screw and has the spring loaded action (like the stock auto button) so you push down on the ball and it shifts?
Are you going to use the auto boot or a manual boot?
Plz post install and final look pics when you get it. Interested in this.
daltron
Rowing All Day
California
Jonathan
2016 GT PP
Nothing wrong with an auto with a blank ball on it. I agree dont pretend it's a manual with a 6spd pattern on it though.
I'm not saying I'm against changing it out, I just find it curious like you said when they put a manual pattern on.
Blk2015GT
2015 GT
Agree but I think that was just a test fit with parts the poster had on hand- proof of concept.
aggieStang
aggieStang
Refugio, TX
2015 Mustang GT, 1965 Mustang Coupe
That is correct. The knob will push down to allow a shift. I may use the manual boot or just make a custom one. Havent decided yet but i will keep you posted.
BULL1TT
culpeper, va
2015 mustang GT, 2001 Bullitt
The stock setup also has a spring loaded action. This is built into the mechanism and not the knob. Mine works just like a factory setup. Push down, shift, let go and it pops back up. Like others have said, I used this method to test my idea to see if it would work. I'm not trying to pass the car off as a manual. It's just that the factory auto shifter is flat out ugly and using the stock knob was the cheapest way to test it out.
magnetic5oh
Kirkland, WA
Vadim
2025 GTI
Keep up the good work :cheers:
