Any easy mods for torque
bootlegger
Enginerd
Mount Pleasant, SC
James
Ex 2008 Mustang GT Owner
Thanks. Good points all around.
So the Active exhaust has the same midpipe as normal exhaust?
I'm not interested in E85 - it's rare where I live and the closest place is almost an hour away - it's a non-starter.
But I am in a 93 Octane state, so that helps.
Correct. Both versions of exhausts are the same back to the muffler. The muffler and baffles are different if you have active exhaust. If I couldn't go E85, I would do ported TB/IM, headers, and a PBD or Lund 93oct tune.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
I have trouble putting power down on a 93 tune with the '18 manifold on my normal street summer tires (275 square setup). On my sticky track/autocross tires I can still get them to spin through 2nd but it takes significantly more effort.
Cavpilot2k
South of Boston
BMW 135i (modded)
Okay again forgive me, I'm new to the Mustang world - these cars aren't tuned for at least 91 from the factory?
I'm coming from the BMW world, where everything, even the non-performance cars, come from the factory tuned for 91 and the higher-performance versions will see definite benefit from going to 93 even without a tune.
I guess I made the, apparently inaccurate, assumption that "performance car" means optimized for 91-93 octane.
BmacIL
Enginerd
Naperville, IL
Not really, no. It'll perform a little better on 93 vs 87 but it's not 'tuned for' 93. It's not that noticeable on the stock calibration.
An actual tune, either from the likes of AED, Lund, PBD or the Ford Performance PP's is a pretty significant (+20-25 whp) increase in power/torque and response all the way through the powerband, even on 93.
Cavpilot2k
South of Boston
BMW 135i (modded)
Add some longtube headers into the mix and that's about the best combo you can run until you add a blower/turbo into the mix.
Texas Speed Headers
https://www.lethalperformance.com/f...ote/exhaust/headers-1/long-tube-1/texas-speed
Pypes Longtube Headers
https://www.lethalperformance.com/f...gt-coyote/exhaust/headers-1/long-tube-1/pypes
So even for increased low-end you would recommend long headers and not shorties? I'm coming from turbo tuning, so I'm new to headers, but I thought the conventional wisdom was shorties for low end response and torque and long tubes for higher end increases.
Please feel free to educate me.
DLW
Union City, CA
2019 Mustang GT PP2
I would have to agree with that being more common in general. The mentality around here is more geared towards mid-top end where these cars make their power anyway.
I do not have any real complaints about my 2019 bottom end, its fine for me, I don't race from light to light and I don't tow.
I think if your looking for low end grunt and not necessarily mid-top end power the mustang should fall to the bottom of your list or put a SC on it as had been said a few times.
I don't personally see a big expectation of gains from just putting shorties on, which may yield nothing over the stock manifolds in terms of low end torque, at least noticeable ones.
Also, regarding only the 18+ year Mustangs, I have talked to both Lund and PBD about tuning these years. Both said there is not much extra power to be had from just a tune alone on these years if all stock, unlike the 15-17 years.
They both said the biggest gains to be had was going to E85 and LT headers, up 50 whp more has been seen. Not sure what gains are seen in the 18-19 models from just CAI, exhaust and tune, my research had not expanded out that far yet.
GregO
Illinois
S550 GTPP
And another " I'm not interested in E85"
Cavpilot2k
South of Boston
BMW 135i (modded)
ALso, anybody have any thou
Would you tune your car to run on E-85 if the nearest place to get it was an hour away on the other side of a major, traffic-congested city?
Your answer, in case you were debating, is no - unless your car is a track/dragstrip/garage queen.
Believe me, I'd love to, but it's absolutely not a practicable solution unless the car was to be a track/dragstrip/garage queen. I drive my cars. Every day.
Which means E-85 is a non-starter except for occasional use.
GregO
Illinois
S550 GTPP
I'm not an E85 Cheerleader. We're on the same page as the OP who isn't interested in burning Moonshine.
Cavpilot2k
South of Boston
BMW 135i (modded)
Sorry man. I misinterpreted your intent. I thought you were leaning toward “here is another guy who is avoiding the obvious easy solution of adding E85 to the mix”.
On the BMW 1-Series forum I’m very active on everybody is always pushing E85 and running tunes for E30 or E40 mixes.
That’s great if you have access to it, but I don’t. Plus I don’t think it’s a good option for daily driver cars, but to each his own. Many of them run meth too, but I like things simple, so I run 93 pump gas.
Sorry if I jumped the gun on my response.
CrashOverride
Under a hood
2015 Mustang GT
I had an N54 Cobb tuned 135i. It was awesome and had tons of torque down low, but just about any near-stock turbo-pressurized "performance" car is going to have more torque than an N/A car. That's partly why Diesels have turbos. Apples are being compared to garden rakes here. Most factory cars with turbos though run out of steam at higher RPM because they purposely use a smaller, quicker-spooling turbo to make the car have more down-low torque to "feel fast" around town. Is it smart? absolutely, but does it make as much power as the engine can? No. You fix that by bolting in a larger turbo, and guess what? The torque goes out the window because of spool issues.
I would argue the easiest way to gain torque on a 15-17 car is the Ford Power Pack 1 tune. Yes it's cheesy for a $450 tune, but the torque increase is substantial. And it is most definitely easy. If you want to wrench on your engine more, and really work against what it was designed for, then the F150 IM is a good idea. After that, short of running some other tune (Or e85), everything becomes "hard" or expensive. I would say the next set of mods would be shorter final drive gearing. Although it won't make more torque, it will put more torque to the ground simply due to the multiplication of engine torque, and it will make the car feel as if it has more torque.
I do feel the car is down on torque, but I would argue that it's not that the 5.0 has low torque (It doesn't), it's just that bigger engines and FI engines (are capable of) have more torque at the same RPM. It's in the laws of physics, and current understanding on how engines work. You can only get so much intake swirl/tumble out of a design at low RPM. OHV engines are typically bigger (6.2, 6.4, etc.) and because they have less valves, tend to stifle flow at just about all RPMs, so they "appear" to make more torque down low. Problem is, they feel that way because they (in stock configuration) run out of steam at higher RPMs. F1 engines don't have much total torque down low either, but they are tiny engines that have powerbands where normal engines explode. I think us "ex-turbo" owners need to shift our driving styles until we re-acclimate to N/A cars. I find myself thinking "I should be in 3rd" but I leave it in second. You can be lazier with a turbo car and lug it, and the turbo makes up for your laziness by increasing the wastegate duty cycle, then you get more boost, and then *presto* you have more torque (At the same RPM). N/A cars aren't like that, you want more torque? The only thing you can do is move the revs higher into the powerband.
I hope you do not take the "laziness" comment as an insult - I fully drove my turbo cars that way. I shirt-shifted them all day long because there was no point not to :)
Of course, the best way to fix it, in my opinion, is to go FI. I won't for a while, but that is in the long term plans. Although I would prefer to go with a turbo setup, I'll end up supercharging it because I have to deal with CA emissions here.
Cavpilot2k
South of Boston
BMW 135i (modded)
All good points. I do like the idea of the high-revving V8 - I just want a little of that shove in the back off the line too. It would seem there should be some way to get a little of that without compromising the top end, which I think is what the OP and I were getting at.
As has been mentioned before, maybe tuning can remove some (or all) of the torque limiting down low (if that is even used on the 18-19 models, which seems to be in debate).
But I agree with you that there is an "apples to garden rakes" comparo going on here, and adjusting driving style for a car that simply drives differently is the most appropriate thing to do.
But that shove in the back from low speed/rpm is addictive...
1bad66
Soddy Daisy TN
'18 Mustang GT PP1, '66 Mustang, '18 BMW X3, '97 Tacoma
This right here is it ^^^ .
I've owned and driven just about every combo you can imagine, from big inch n/a engines in light weight hot rods to hi revving DOHC domestics to turbo'd Bimmers just to name a few..You must, and I repeat must adapt your driving style to each combination. You have to drive a coyote car a lot like a high revving small cube 4-banger if you want the best experience. You cannot lug the Coyote around at low RPM's (typically under 3800) and expect anything other than to be underwhelmed. My wife's turbo cars??? a totally different story...Lug that muther around at 1500 and it'll pull off with a lot of grunt when needed. That's my .02
BmacIL
Enginerd
Naperville, IL
The shove is certainly exciting at low rpm, without a doubt. That said, the continuous and building pull all the way through 7500 is just as addictive. It's smooth and doesn't have as much jerk, but the acceleration is there. And the noise on the way there is so immensely satisfying. In particular, the way it pulls in 3rd-5th at high speed is the most impressive thing. 70-110+ is a thing of beauty. That's powerrrrrrr (channel your inner Jeremy Clarkson).
