700+ hp 5.2L flatplane voodoo
EFI
Masshole central
5.Br0
I would knife edge the crank.
Titanium rods.
Forged Pistons.
Rework the heads.
Custom intake / induction and fuel system.
Raise the compression.
Custom cams.
2" headers.
9000+ RPM!
Looking at your mod list, although seems extensive, not really sure where you're going to pull 200hp out of...especially on a setup already pretty well optimized.
Headers 30
Intake 20
Compression 10
RPM 30
Cams/headwork 60
You're still some 50hp short and that's being fairly generous on each one.
Darkane
Alberta
2016 GT350 Base
Headers 30
Intake 20
Compression 10
RPM 30
Cams/headwork 60
You forgot he's on 100oct fuel only.
Your compression of 10hp is silly and unrealistic. He can run 13.5-14:1 with that knock resistance.
At that compression with stock cams he'd see - well whatever maybe 50? Impossible to guess unless I calculated it and I'm not going to do that today.
Voodooo
Voodooo
SE Michigan
Scott
Carroll Shelbys Soul Lives Under My GT350 Hood
Headers 30
Intake 20
Compression 10
RPM 30
Cams/headwork 60
Not looking to pull 200hp. 174 would be nice. Lol. 200 additional would be 726hp.
pinero61
Houma, La
'15 Ruby Red Base GT PP
Well, we just saw a Boss 302 make 600 whp NA on stock compression, and I won't be far off that mark with my NA build.
There's no reason the 5.2 can't pass me up. With heads, cams, intake, and exhaust, you'll probably be pretty close to your goal on a good fuel.
Voodooo
Voodooo
SE Michigan
Scott
600rwhp is damn near 700 crank hp. I know this is doable.
EFI
Masshole central
5.Br0
100 octane is marginally better than current pump gas. Not saying that he won't be able to run 14 CR but let's not make this out to be equal to say it's the same as 116+ race gas. And it's about 3% increase per full point of CR, so 6% total power. Closer to 30 if he can truly run 14+ CR with no knock.
Let's just say I'm skeptical, but welcome to see that if it works.
Voodooo
Voodooo
SE Michigan
Scott
How is 100 octane marginally better then 93? I've built pushrod 289,302 and 351 windsors also built 2 401 svo blocked Yates headed windsors with 13.0:1 compression and also a Neal Brodix headed 401 svo Windsor all naturally aspirated with well over 800hp. It's 2016 not 1970. It's not uncommon to get 2hp per cubic inch. Granted the cams and intake will be custom but it can be done. Just as others said, a boss 5.0 on another forum just laid down 598 rwhp NA. That's damn near 700 crank hp.
Voodooo
Voodooo
SE Michigan
Scott
I remember being one of the very few supporting lethals idea of putting a blower on 12.0:1 compression when others said it wouldn't work. 819rwhp later who's laughing? That's 12.0:1 on E85. With 11psi
pinero61
Houma, La
Exactly why I mentioned it. Not sure why so many are saying it's not possible.
Voodooo
Voodooo
SE Michigan
Scott
Yeah I know. I see a guy on trackmustangsonline do the same with his boss.
pinero61
Houma, La
Why a custom intake? Slap a ported CJ on there with the dual 65 TB.
Voodooo
Voodooo
SE Michigan
Scott
I already trial fit the cobra jet intake last winter and it will not fit under the stock hood. And you can not lower the engine over 1/2" because of oil pan to K member clearance.
pinero61
Houma, La
Ah, that inverted hood scoop screws you, i'd imagine.
Darkane
Alberta
2016 GT350 Base
Can we get a link to the 600whp boss? Unless he went increased displacement I call bullshit for being stock CR.
The k24 Hondas are making 300whp with 13:1CR on 93 octane. A coyotes doesn't breathe as well, doesn't rev as high and has less CR. Bull.
I bet it was on a dynapak.
Gigantor
Arizona
Wes
2016 Ford Mustang GT Premium
