Turbo gen 2 voodoo?
dblcbra
Lowell, AR
Robert
2019 gt350R, 2019 mustang Ecoboost, 2017 gt350(sold), 1996 xlt bronco (351), 1995 cobra, 1993 lx
What are your thoughts on turboing the gen 2 voodoo? I had seen many post about people worried about blowing their motors with the gen 1 motors, but with the changes that have come for the 2019s, would this be a safer route?
Bulldogs22
Atlanta
2019 Shelby GT350
The block is indeed stronger and I think it could handle the power output of current forced induction setups fine with good reliability. But like anything higher HP applications is trial and error so someone will probs have to blow the engine to find its limit.
honeybadger
Just don't care
COTA
Kevin
'17 GT350
While the block is definitely a step up from the Gen 1 block for FI, there are some other areas that are still not designed for it - namely the compression ration and valvetrain. As @Bulldogs22 said, it'll be trial and error. I highly recommend speaking to FatHouse. They have a ton of experience with Voodoos specifically and give you a good direction. It's not that the Voodoo can't handle boost, but that you need to understand the limits of it and I don't think anyone understands that better than Fathouse.
firestarter2
NYC
RR G350 Track
Block strength is rarely the limiting factor in force induction at least not at first.
honeybadger
Just don't care
COTA
Kevin
'17 GT350
The changes for boost are more than just strength though...they made changes to the water cooling jackets, oil squirters, etc. Additionally some changes were made to the piston/rings, etc. that are also better suited for boost.
Still not ideal, tho.
firestarter2
NYC
RR G350 Track
I didnt read all the changes at glance based on what I saw compression will still limit you before block strength or heat killed the engine. Unless you are running e85 or something.
Changes to the rings "could" be worse for FI.
GrabberBlue
Phoenix
Alex
2017 Grabber Blue GT350
You can get some reliable low-medium boost on the Gen 2.
NUTNDUN
Dover, PA
George
2019 GT350
Most of it is going to be how good the tune is. With variable valve timing compression isn't as big of a factor like it used to be to an extent.
nastang87xx
San Diego, CA
2016 GT350 Track Pack
I thought they were the same block
The Voodoo block is further reinforced in many areas such as the water jackets, the valley, the head bolt bores, etc etc. The Voodoo block uses the Coyote block as a framework, it's not just a bored out Coyote.
Ninjak
Posting from the Shadows
The Shadows
David
2024 Dark Horse Supercharged 2024 Bronco Raptor 1968 GTA Mustang
FatHouse has the turbo game down. They have quite a few cars out there running, and I have yet to see a post about one of there builds breaking down. Now they are expensive......but I guess for peace of mind, for some it's worth it. I would not mind doing there 800 build. Just cannot justify the money to do the build.
Demonic
Boston
GT350R
Yes, definitely different blocks.
olaosunt
Indiana
Not as different as you may think .
The Gen 3 voodoo has the same valley (with the cast in braces ) and longer 12 mm head bolts .
The deck surface is different with the Coyote being more open
Droopy1592
Atlanta
Damien
2017 GT350
I thought the gen 2 voodoo (2019+) had all of those improvements (Same as GT500 block) and that the gen 1 voodoo (15-18) was essentially the gen 2 coyote block, with the coyote (2011-17) having iron sleeve/liners and the voodoo having pwta. I could be wrong but that’s what I remember.
