6 Piston brake question
luc
CA
2017 GT with PP
That's not quite true, the piston seal is a seal keeping the bore of the caliper free of contamination, so as not to bind.
The pad retracts as the fluid pressure decreases - neutralizes. Second, a rotor that has run out or as you say is warped. Will cause the pedal to pulsate when the brake is applied.
Sorry but it’s the seal that retract the piston
The seal has a square shape and deform slightly when brake are applied. Once fluid pressure is removed, the seal go back to its original shape and drag the piston back with it
paulm1
Northeast PA
pau
2021 GT mustang
could be a bad caliper, you may have a piston(s) starting to lock up. How many miles are on it?
Howitzer
NC
flickr.com
Howie
2015 Mustang GT, 2000 Mercedes C280
Have you ever seen the shields on a car equipped with the Brembo?
They are so small that it is almost impossible for them to make contact with the rotor
And, btw, they are not dust shields at all but rather heat shields for the ball joints (on Brembo)
I have the small shields...can confirm they can still be bent to touch the rotor and squeal. I've accidentally done it myself.
Comp550
2015 Mustang
I changed the rotors and pads about 5 years ago and they have about 15k miles on them.
