305/ 315 combo
Bike4pizza
Michigan
‘19 perf blue, recaros, handling,tech,carbon dash
Can I run this combo on 19x11 front and rear? Looking at some apex sm10s with the promo they are running
MAGS1
Somewhere in Middle America
Mark
2022 Mustang GT
As stated above, yes that will work. Apex has a good deal going on right now, tempted to buy a set myself. I’ll probably have to sleep outside for a few nights if I buy another set of wheels though 😂
Bike4pizza
Bike4pizza
Michigan
thanks. Was skeptical since OEM is +/- 0.5 between front/ rear. Like the idea of running staggered or square depending on the tire deals I can find! These will be a track oriented set up
Flyhalf
CA
www.youtube.com
Alessandro
Mustang GT 18 10speed auto PP1 , GT500 '21
Why 305 315? Just go square.
Or 305 or 315☺
Will also suggest to take the front wheels with rear offset and use hubcentric spacers. 28mm.
So u can rotate wheels for better wearing
Apex are the best
NightmareMoon
2016 Mustang GT PP w/ Voodoo
In short, you certainly could put 305s on the front and 315s on the rear, it would work just fine.
There's something to be said for prioritizing getting a front tire as wide as the rear tire because of our slightly front heavy weight distribution, and Flyrite is right that square rotatable 315 wide setup is the kind of the ideal option from a lot of angles.
At the end of the day, as long as you at least have camber plates to get your tire wear and front grip sorted, a 305/315 non rotatable setup will be fine.
WItoTX
Houston
Kyle
'17 GT350
Yes. But a 315 isn't an objective size, each mfg size is different. Some brands you will be pinching the tire, others will be stretched.
Flyhalf
CA
www.youtube.com
Alessandro
U can fit
315 30 18 yoko a052
305 30 19 3R or supercar3
305 ps4
305 Falken 660
315 hoosier
There are many options.
If in doubts. Just go 305 squared. :)
