3.73 gears...starting in second??
ZIGZGT
Wentzville, MO
2016 Race Red GT Premium PP
I have the 3.73's. Unless I'm planning on getting on it hard from a stop I almost always just use 2-4-6. No reason for the other gears. If it's shuddering, you aren't doing it right. Practice more and ditch that clutch assist spring if you haven't already. Good luck!
DivineStrike
Doomsday
Charleston
15 GTPP, 11 F150 FX4, 07 CBR600RR
This will kill the clutch even more considering We have the rpm hold software in the car. Skipping shifts now cause more clutch wear Especially 2 to 6 and 3 to 6 shifts
ssyellow
Michigan
15' Competition Orange GT - PP/Recaros
This will kill the clutch even more considering We have the rpm hold software in the car. Skipping shifts now cause more clutch wear �� Especially 2 to 6 and 3 to 6 shifts
Exact thoughts I had. Listen to this man.
Charles147
PP w/50AP
never killed a clutch and I've been skipping gears for years.
DivineStrike
Doomsday
Charleston
This car is different than your other cars. How many of your previous cars hold the rpms where the next shift should be? Even a 4 to 6 shift wears the clutch in these cars. Double clutching doesn't disengage the rpm hold either if I remember correctly. The programming holds the rpms for a few seconds or until hitting the brake. That said i still skip shifts but I understand it does cause increased wear on the clutch.
skytop1
Boynton Beach, FL
Shelby GT500
If you have good clutch control and are not aggressive, you can start in 2nd (on level of down grades) with no problems to your clutch.
dev1360
STL
DIB 2016 S550
FWIW, 2nd in this car with 3.73s is STILL SHORTER than 1st was in my C6. That said, I start in second almost every time when normal driving. Even creeping in parking lots. I pretty much only use 1st if I'm going to get shitty.
And as far as the RPM hold...I hate it. Loathe it. Want to burn my car when it does it. Let me drive the God damn car, Ford. I don't need extra gas when slipping the clutch, and I don't need RPM hold between gears.
  • Like
Reactions: CB
skytop1
Boynton Beach, FL
Shelby GT500
That was not my car. It is from the AirStream website.
I made a similar mistake once towing way over weight with a short wheelbase SUV.
Long wheelbase is very important to have when towing a large or heavy load. It provides directional stability and supressing trailer whipping. Jack knifing is the worse scenario to experience.
Sasuketr
Chicago,IL
2015 Ingot Silver GTPP
I start at second too sometimes. I just use the friction zone, no problems at all! Especially when its below zero degrees out and the trans fluid is not warm enough thats what i do. First to second on really cold temps and cold engine is a pain.
GoBlues38
St. Louis, MO
Scott
2015 Mustang GT, Premium, 3.55, 20" Foundry, 6 Spd
I usually skip 2nd and 4th when i am driving normal.
paul123
'16 Mustang GT
I tested this, rolling start in 2nd, ran it up to 4000 RPM and switched to 4th gear, and it lugged, below 1500 RPM. My car has 3.55. All the fun is watching the tach move (fast) so I don't know why people would skip gears.
