2nd time going to the track advice needed
SAY WHAT
Tim
2016 mustang Gt
My 1st time going to the track at summit point was in February Cold weather on all season tires.
Mostly stock car except a tune, exhaust and fords track handling pack suspension.
Mods since then
  • 2018 ported intake
  • lund e85r tune will be using this on the track
  • 170 T stat and on 100% water with vp racing cool down additive.
  • 255/40/19 fronts and 285/3519 rear mps4s
So first question for the peace of mind, is it safe to run 100% water in the warmer months? Or should I be running %15 like some folks suggests? Or do I do what ford asks and have 50/50?
Water boils at 212 but with the s550 cool system running at 21 psi I think the boiling point would be around 260F. I should be okay since we have about 10 minutes between laps.
Next question is tire pressure, what should they be hot? Last time I was there with the all seasons I maintained 32 psi by letting air out but i saw as high as 36-38. Ill be driving there in the morning so I could check them when they are cold and add air.
dmann
Alabama
2018 GT PP1
Mods since then
I would stick to the recommended coolant solution and as far as the tires are concerned. start at 32PSI cold and bleed off if needed. A hot pressure of about 34/35 is ideal. I noticed the tires getting greasy about 37.
Plimmer
San Antonio, TX
Rob
2015 Mustang GT
Water will be fine, but definitely use distilled water, else you will get corrosion.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
I don’t see a need for adjusting away from the Ford coolant ratio.
Tire pressures - keep them at or under 37. 36 is probably more ideal. 38 is getting up there.
JohnD
Legend in his own mind
beyond the pale
2023 Mach 1 track day car
I was seeing temps of 252F on a recent track day. I don't think I'd be fooling around with anything but Ford's recommended coolant.
Grintch
Hunstville
2015 GT PP
Pure water + water wetter provides the best cooling. Most race organizations actually outlaw glycol coolant because a leak makes the track very slippery.
That said, for a track day I wouldn't change a thing. Run the normal 50/50 mix, the cooling performance is in the same ballpark and I have yet to see a Track Day organization complain about anyone running conventional coolant.
Nick
Nashville TN
www.trackstangs.com
Nick
2017 Shelby GT350
I've run water all weekend before in the summer. Not by choice but it was all good in a pinch. Drained and switched back to 50/50 mix once I got home.
