2020 Mustang TCU
Augustg
AUGUST
2020 Mustang Eco premium convertible
I was informed by my dealer that my Modem is not communicating and needs to be replaced. Any suggestions. Is this something I can buy and install myself?
Skye
≈39N
"Skye" Mach1 N2144
You probably can, but it's my understanding the TCU is VIN-specific; it would have to be programmed by the dealer or provider first, like a key.
I'm going to point to some references which could help with the swap.
https://www.mustang6g.com/forums/threads/s550-electronic-modules-and-their-networks-a-primer.195769/
Edit,
I'm doing some deep dives on this now.
The physical swap is easy.
The logical programming is somewhat involved. The installer needs to program the TCU to match the as-built data of the car, then associate that TCU with the car and Ford. For those who use FORScan, FDRS and other products, it can be done.
EFI
Masshole central
5.Br0
Modem is easy to swap (in the trunk behind a panel), but you have to confirm if it needs to be programmed for your car or if it's plug-and-play.
ORRadtech
Atlanta, Georgia
I'm a bit confused. The TCU is the Transmission Control Unit, correct?
The Modem connects the car to the internet, correct?
What "needs" replaced and why? Or what do I have wrong?
TrueBlue22
Southeast Michigan
2022 2.3L High Performance Package Fastback
TCU = Temematics Control Unit
TrueBlue22
Southeast Michigan
Thanks. Don't people deliberately disable that so Ford spy on you?
Easier to just unplug the modem, I think. The TCU in my 2020 Escape seems to have disabled itself though. Lost connection to Ford Pass, can’t reconnect. Modem will talk to a wifi network, so it’s not the culprit.
Yep. So did the OP buy the car new or used? If used, it’s possible a prior Tinfoiler disabled it…
Augustg
AUGUST
Do you know where the TCU is located in my 2020 mustang.
sirben711
Missouri
Ben
2021 Mustang Ecoboost 10R80 w/ FP Tune
Although... if you don't want Ford to collect information about you then I wouldn't do a thing...
Augustg
AUGUST
In the trunk, left hand side, behind the trim.
See the attached document.
Thanks so much. So it looks like I have to bring it back to the dealer to program the new TCU
ORRadtech
Atlanta, Georgia
A good mechanic will/should have the ability to program modules. Or you could with the right scan tool. Unfortunately those are $4k and upwards with a hefty annual fee so most DIY guys won't have one.
