2019 Procharger P1SC-1
acere23
acere23
Fl
Tony
2019 Mustang GT
Who tuned your car? I was going for that same injectors, pump, but different bap and a lot of these fellas said the reputable tuners would not touch that convo for E85.
PBD tuned my car..I found them cheaper at sportcompactwarehouse.com
Advertisement
SSG 5.0
2017 Mustang GT
I’m going to call them soon and I might go back to my original plan if everything works out. Thanks for the info as well.
acere23
acere23
Fl
Tony
2019 Mustang GT
Is that about the limits of that fuel system or do you think you can get more out of it?
I'm limited to my bypass valve wich is 10lbs.. you can push it a bit more with a bigger one and get around 800+ to the wheels
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Limited by your bypass valve?????
TGGT
SoCal
2018 mustang gt
man I’m super nervous about trying to get 800 out of my car with a twin pump and return line setup. Hopefully I’ll find out this coming week if everything is good or not.
acere23
acere23
Fl
Tony
2019 Mustang GT
What system are you running?
TGGT
SoCal
2018 mustang gt
a stg 2 d1x with id 1050x, gt350 twin pump, and an aeromotive fpr. I’m running a 4.5” pulley which will probably put the boost around 14-15 psi. I’m driving around on a base tune right now until my tuner gets time to put it on the Dyno so I haven’t been able to get on it really.
acere23
acere23
Fl
Tony
2019 Mustang GT
You're set then.. I'd say should be around 700 on 93 and 800+with E85
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Elaborate on the bypass valve you mentioned.
acere23
acere23
Fl
Tony
2019 Mustang GT
The bypass proflow its only good for up to 700hp max per procharger specs.
Youll need a bigger one to get more out of it like the race bypass
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Oh gotcha
Toy Cobra
2018 GT
I j stalled a TiAl q50 in the exact same location as the factory bov pipe with great results. Score and after picture for comparison.
Advertisement
89 - Solo Performance - 1
Advertisement
