Sawyerjames
- Oct 4, 2018
- Charlotte, NC
- Adam
- 2018 mustang gt A10
- Vehicle Showcase
- 1
Any help would be greatly appreciated... Background story below...
I have a 2018 GT A10 with 20,000 miles. The car has been Procharged for 10,000 miles now. I am tuned by Lund both on the Dyno (remote) and street logs (obviously remote). The first dyno run the car only made 550whp and was being robbed of timing. I was told by the tuner that the high compression motor does not handle boost well on 93 pump gas and that we needed to run a can of octane boost. I have been running a can of Torco at every fill up, along with the best 93 gas around Charlotte NC. With Torco in the tank the car still only made 615whp. I am not a huge numbers person, but this still seems low. I guess I am reaching out for some help/advice on things I can check for or try. Lund says the logs look good, and the gas in Charlotte is what is holding me back. I just don't see every 2018 GT with this set up having to add meth, E85 (not available), or octane boost to make mid 600's and if I would have known this before hand I would have gone a different route boost wise. I am at a dead end with Lund as they say there is nothing else they can do tune wise to get more power. Is anyone else having this issue and what did you do to resolve it? The only thing "off" about the car since the install and tune is that on hot starts the car barely starts up, and is really quiet upon start. It idles down really quick to below 500rpms, almost shuts off, and then corrects itself. The only thing I have been able to notice that looks strange is my red race valve is only halfway open at idle (is this normal or should I adjust) Any advice would be really helpful in trying to figure this out. Set up is below, and thank you for taking time to read this...
P1SC / stage 2 intercooler / 4.10 pulley / red race valve (open) / ID1050 injectors / Brisk Colder plugs / DW400 fuel pump boost / Corsa Extreme Catback / 3.15 gears / still on stock headers
