2019 B&O Subwoofer Install Help?
nathanks
2019 GT
Curious, most everyone else has had a positive response. I wonder if your experience is due to subwoofer choice?
I doubt it. The Dayton is a great sub. The biggest limiting factor will always be the amp, and in this scenario the stock amp just isn't getting it done.
Assh
NC
2019 Race Red GT
Black and Purple wires go to the negative input on aftermarket sub.
Yellow and Green wires positive input on aftermarket sub.
I've got all that and my new sub has DVC with 2 connections. Then it doesn't really matter which connection each pair of wire connects as long as the polarity is correct.
Thanks.
m3incorp
Georgia/Colorado
James
Correct
Thanks.
gpierce
Australia
Greg
2020 Ford Mustang GT Convertible
To me the Dayton sounds better and is tighter than the factory sub. Always planned to install an amp though. Bought a Rockford R250 just haven’t installed it yet.
steve0s550
AZ
STEVE
2020 HPP 2.3 Mustang
Old thread but if hooking up a DVC 4ohm speaker is it putting a 2ohm or 8ohm load on the stock amp. I know it depends on if you wire it in parallel or series. How did you guys end up doing it?
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
I assume each voice coil is 4 ohms.
Parallel is 2 ohms overall, and series is 8 ohms.
If you have stereo left & right channel signals available, then run one into one coil and the other into the other. The two signals will "sum to mono" electro-acoustically". The amp is happy because each channel sees a 4 ohm load.
steve0s550
AZ
STEVE
This would be just replacing the stock B&O 10" sub with the stock amp, after reading through all these threads there are two clips with two wires each and there are 2 positives on one and 2 negatives on the other?
gpierce
Australia
Greg
Yes. So you connect one pair to one of your coils and the other to the other. The stock B&O is a 4ohm DVC sub.
steve0s550
AZ
STEVE
What if I did a SVC and just twisted the 2 negs and 2 pos and hooked up that way? Would that cause a problem with the amp?
Gregs24
Wiltshire UK & Charente FR
Greg
Mustang V8 GT, Ford Kuga PHEV
Yes. Don't do that. You are connecting the positives of two amp channels together and it won't like that.
I think that is what some people do with a SVC sub. Of course driving just one channel and leaving the other disconnected would significantly reduce the power output. Just use a DVC sub is the obvious solution !
steve0s550
AZ
STEVE
I went ahead and ordered the Pioneer DVC 4ohm and will install it this weekend. Already popped off the trim piece with no damage and added 8oz Poly Fil for the time being 👍🏼
GTP
Deutsche Pony
Indy
Philip
I broke half my grille tabs. How did you do it?
Would be great if you documented installing the Pioneer woofer for us.
