2018 window randomly moves up and down 1/4 inch
Tlauc1999
Morristown NJ
Tanner
2017 Mustang GT
I’ve got this problem in my 2017 S550. Stupid question but it’s not going to kill the battery while I figure out a solution, right?
Firsttexan
2011 GT500 '19 GT PP1 '13 GT500, 98 GT, 92 LX 5.0
I’ve got this problem not in my 2017 S550. Stupid question but it’s not going to kill the battery while I figure out a solution, right?
It should not cause a battery draining issue.
Mine did that when I was test driving it. The dealer installed a new window motor under warranty. They said, it is a common issue. Maybe it was just dirty contacts as stated in this thread. Silicone grease can work wonders.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
It could kill the battery. It will go up and down even with the engine off and car parked.
SteelerJAXX
Myrtle Beach, SC
Jack
2016 Mustang Convertible 3.7L V6
My 2016 Convertible does this constantly on the passenger side. My wife calls her CHRISTINE. She is just waiting for the old music to start playing, and she said she would jump. The Schizophrenic window does calm down at some point, or we just have the top down and don't care about it. My battery has never been below 12 Volts even when its in my garage when I'm out of town for a week.
DaBladestorm
Deltona FL
Michael
2018 Mustang Convertible, Silverado 2500 Duramax
Well, Thanks to all you guys, you have saved my last bit of sanity I had left. I had this issue was driving me nuts.
Tried the Recalibrate (No Luck)
Found this thread and found the plug. No water in it since garage kept and not out in rain much but tried anyway.
Used Electric contact cleaner on plug. Then used De-electric grease as noted.
Well resolved the issue.
Guess there was some corrosion in there on that line caused the issues.
So thank You for this, without it would have cost me fortune going to dealer and watching them play wack a Mole for part replacement.
K4fxd
NKY
If it comes back, mine did after about a year, you need to replace the window motor.
kipp
Baton Rouge, LA
Kipp
2018 Mustang GT Convertible
Nothing ultimately worked for me until I had the motor replaced on that passenger window. A year later the driver side started doing the same thing and I just went straight to replacing the motor. The shop determined it needed a new pigtail on the driver's side too for some reason.
DeepImpactS550
Longwood, FL
2016 Mustang V6
I did this when I replaced the door speakers. Worked great for several months. I still get an occasional random few cycles of the window, but it's much better than before. Oddly, the last time it acted up, it had been completely dry (no rain) for a few weeks. FWIW, my connector may have something to do with it. It took A LOT of force to get it to actually "click" after adding the grease.
Neko-
Netherlands
2019 Mustang EB
Would like to chime in that this helped my mechanic tremendously in figuring out the issue and taking some decent steps to resolve it today (hopefully permanently, but time will tell).
Connectors were wet, so those got cleaned out, dried and then taped in to prevent water from getting in as much as possible.
Mechanic did comment on the poor design choice of the connector for the window motor being plugged in in an upwards direction.
K4fxd
NKY
I did this and it lasted about another year when I had to replace the window motor. I now suggest replacing the motor and filling the plug with dielectric grease.
klemsonguy
Greenville, SC
Kevin
2018 Ford Mustang GT Convertible
I just wanted to say thanks to all of you who posted here for pointing me in the right direction to fix an issue that has been a regular annoyance for over a year! Also, I found a pretty good YouTube video that walks you through how to address this issue so that it will hopefully help someone else out if they come across this forum in the future:
G.T.
Asia
Glenn
2016 Ford Mustang GT Premium
Another thank you to all the participants of this thread sharing lots of great advice and experience!
Cleaning and dielectric grease application just done on the passenger door sockets and it appears it worked. No more jumping window for now, and I hope it lasts!
K4fxd
NKY
Unfortunately it won't, be prepared to replace the window motor unit within a year.
Tycoon
PA
2018 Mustang GT Premium
Yes, that is one of the 3 plugs I did on my second attempt. So, in my case it very well could have been that one for me as well.
Pulled the interior panel last weekend and cleaned all the connections I could see (did not touch the door latch) with electronic cleaner, reattached. I believe fixed. Have driven a lot since I did this and no issue. Only been a few days though. On the window motor plug, it felt like it would not snap onto the motor. I pushed it in as hard as I could without feeling like I was gonna break anything. I saw some corrosion there. Electronic cleaner seemed to have removed the corrosion. I think it's just that connector. Did not use dielectric goop.
