2018 GT PP1 Diff Gauge
greengoblin31
pittsburg
2017 mustang
Thanks for all of the responses; dealer stated that it tested fine no codes etc etc however they were told to put the gauge in boiling water and then reinstall . The gauge is now working.
wow that's pretty nuts. who would of thought a thermal resistor would need that kind of waking up. i've heard of people boiling the thermostat to make sure it's opening at the correct temperatures and what not; but never a sensor lol
thanks for the information man!
good old trick right there to keep in thought :hail:
Put the gauge in boiling water - or the sender??
orangefurygt
orangefurygt
Does your 2018 GT Tick?
Vancouver BC, Canada
Rick
2018 Gt Premium PP1 6sp /Active Exhaust/Nov17
It probably was the sending unit ; they did not note it on the repair sheet as all it said was that the gauge responds when the diff shield responds; when working at track temperature.
(that is not true )
The manager is the one who explained what they did ie put the gauge(gauge being up front and digital!) into boiling water he probably meant sending unit/ the piece going into the diff itself
FightingFalcon
Germany
Oliver
2018 GT Auto
How do you activate the Diff Temp Gauge?
In my EU-Spec Car i cant find it.
FightingFalcon
Germany
Oliver
2018 GT Auto
Yessir! :)
2018 GT PP1 10R80 and ive seen the Temp-Sensor in the Diff.
Thats why im curious. ;)
db252
Equinsu Ocha
Bay Area, CA
16 GT Premium/PP/Nav
When you are in your pony button settings and it gives you your choice of gauges to display, is it an available option to check and add to the screen?
FightingFalcon
Germany
Oliver
2018 GT Auto
Sadly not.:frown:
Only Choices are IAT, TT, OP, CHT but no Diff-Temp
db252
Equinsu Ocha
Bay Area, CA
Hmm. That a euro thing I’m guessing? It may be possible that you can code it in with forscan.
Nonsequitur
Taiwan
Mark
2018 Mustang GT PP1 Euro Spec - 2014 Focus ST with EFR7163
I also have a Euro spec '18 GT PP1 and I can confirm that it can't display the diff temp gauge.
FightingFalcon
Germany
Oliver
2018 GT Auto
There is a Forscan Code for it.
My Tuner is lookig into it and i will report as soon as i know if it works or not.
FightingFalcon
Germany
Oliver
2018 GT Auto
Sorry, completely forgot this thread.
Works finde with forscan to show the axle temp.
Jsolman
UK
Jason
Mustang 2018 GT (UK) A10
Just reading this, as I've enabled the diff sensor in the gauges section on the digital cluster (UK GT PP1 car), so will go for a drive tomorrow, to see if it moves. Believe it should, as the 18+ has a temp sensor for the ECU to monitor and go into safety mode if it gets too hot.
Its in the IPC section on Forescan. I enabled both Axel temp gauge and Axel temperature gauge options. But wasn't sure if there is a difference between the two.
