bigriver
Hope you get it soon too!!My exact noise. My 15 f150 4x4 was similar but made a rotational noise if the wheels spun with traction control on. Werid as it sounds the noise was amplified x10 if you kept light throttle during those conditions. Hard to explain. I just wish they would hurry up with my rav program on my 18. Have two cars out of 600 mile radius I'm looking at.
Ford approved a new short block for mine. 14 days in the shop and will probably hit 30 so I may be looking at buyback/replacement.
Here is the most plausible explanation for the noise I was having.
OASIS 2888-
Some 2016 GT350 Mustangs might exhibit Piston Rattle from Idle to 3000 RPM
Some 2016 Mustang GT350 equipped with the 5.2L engine may exhibit a rattle or rapping type sound during cold operation at light loads and speeds from idle-3000 rpm. The noise will be most noticeable during light acceleration in the 1500-3000 RPM range and may also be noticeable in the 800-1200 RPM range with neutral throttle blips. This sound is caused by the piston motion in the cylinder bore. This is an inherent characteristic of the forged aluminum pistons utilized in this high performance engine. Once the engine reaches operating temperature the noise will diminish, although it may still be noticeable even when fully warm. There are no durability concerns with this sound.
