2015 EcoBoost Engine Replacement
NY
Paden
2015 Mustang EcoBoost
Was driving the other night, heard my turbo blow off, then a loud crack, then what sounded like something dragging on the ground, and then my engine shut off completely and wouldnt turn on.
My guy hasnt taken ithe engine out yet, but says after his first run of initial tests that its most likely Im gonna need to replace the engine.
Anybody have any experience in that regard? Advice, pricing, timing, engine recommendations? Would love to hear experiences
What is his findings in his initial tests??
I mean, if it was catastrophic engine failure as you experienced and a rod came through the pan or block, it needs an engine.
Is it at a Ford dealer or an independent shop?
You have 2 options:
Buy used
Buy New
If buying used, yes you can find inexpensive deals on some low mileage engines but with limited warranties (or none). This site seems to have some used units, but I don’t know anything mkre than what is seen in the link
Prestige Mustang is located in GA and is well known for years for being a Mustang specific salvage facility - you can try them:
https://prestigemustang.com/
Delk Performance is also another well known facility for salvage Mustang parts for many years:
http://www.delkperformance.com/Salvage.html
Car-Part is another reliable salvage source and you can select by state:
https://www.car-part.com/mobile/index.htm
Midway Mustang is another well known and reliable source: https://midwaymustang.com/
Another member was looking here:
https://enginespro.com/store/ford/m...0f5f9d36fa2829a1bacf11ac9c&prod=EC259436885KP
If buying new, you can get a complete long block with a good length of warranty. I don’t know how accurate the pricing is, but here’s a brand new Ford long block supposedly:
https://www.autozone.com/powertrain...ng-block-engine-fr3z6006f/707530_956844_11266
Then you have to figure in labor if you’re not able to do the job yourself, which could be maybe another $1k-$2k depending on shop rates and other necessary supplies, parts, fluids, taxes etc.
NY
Paden
You have 2 options:
Buy used
Buy New
He said the word "catastrophic" pretty early on in our conversation, everything else was like a blur after that. Thabks for these sites, I'll be sure to check them out!
ORRadtech
Atlanta, Georgia
I'd be curious to know some particulars on the car.
Model year?
Milage?
Any mods?
Diligent on routine maintenance?
Since my EB is my first turbo car I've been a little concerned about its longevity and have thought about what I would do. I've decided that I'll go with a used engine and do the swap myself. I've already set aside a fair amount of money as insurance in case...
Maybe nothing will happen and I can use that cash for a new model in a few years.
NY
Paden
Model year?
Milage?
Any mods?
Yeah mine's a 2015 that I bought used with about 47k miles and it had an MMR air intake kit and was tuned up a bit. Thats probably the genesis of my problem was not doing enough background on how it was tuned before I got it.
Anyway, put on about 6k miles on it since I bought it ~6 months ago, and then this happened. I had just gotten it serviced and threw on some new brakes too -- but no idea how well maintained it was before I bought it.
Definitely enjoyed some fun with her, some revving here and there, some hard accelerations but i wasnt pushing the redline or anything. Will probably take it a little easier now though. :/
ORRadtech
Atlanta, Georgia
Mine is an '18 with right at 66k now. Completely stock but I can't say that it hasn't seen redline a time or 3... Still runs like a top though and I do have cash put back in case.
Good luck with yours, ut sucks that you are going through this but my guess is it's well worth repairing.
NoVaGT
Northern Virginia
2019 PP1 GT Kona
What gasoline were you using? What octane?
FreePenguin
Ohio
Donald
17 mustang
Question
I see a ton of mint 18 engines w 11k miles for sale
No 17’s much.
Can I drop 18 into 17 no issues?
If my current engine has fp, do I just make sure to keep current pcm etc hooked up or is there anything needed changing with a new engine drop in
ORRadtech
Atlanta, Georgia
Question
No 17’s much.
Good question, I'd be interested in the answers as well.
I do know something changed with the '18 + EB because there was a HP bump and it went to the A10 as well. A physical change to how the engine bolts up seems unlikely to me but I could see computer/software changes.
FreePenguin
Ohio
Donald
17 mustang
But if you retain all the ecm pcm stuff off 17. It shouldn’t know any difference in blocks. I’d think
ORRadtech
Atlanta, Georgia
Right, I agree it shouldn't but that extra 10 or so HP comes from somewhere and I don't know where. If it's just a software/tune thing it shouldn't matter at all but if it's a hardware thing like heads, turbos, etc then would the '17 ecm know to take advantage of that or maybe run poorly because of the difference? IDK. Hoping someone might.
FreePenguin
Ohio
Donald
17 mustang
It’s the tune, so if we use our ecm stuff on 17 it would put down thev17 numbers
Or my ford tune numbers.
I think 15-17 eb stock is 18 psi
18-20 stock is 20
Ford perf 15-21 is 22 psi
Ford hpp is 22 psi
FreePenguin
Ohio
Donald
17 mustang
It’s the same engine
Same connections
Same clips
BTDUBS
Portland, OR
2020 Mustang GT
Having been in the VW and Mini world, I can say that tunes absolutely can and sometimes do cause premature turbocharger failure. Usually it just results in a new turbo, but if the impeller or impeller shaft get sucked into the engine, it can cause a catastrophic failure. Usually it isn't just the tune, but the way it was driven too. Whenever you are taking the engine outside of factory spec, issues become more frequent.
That said, I have had turbo engines go 100k+ miles without needing more than a rebuilding of the turbo, when they fail at high miles, it usually isn't catastrophic, just a slow decline in boost.
