2015-2017 S550 Coyote 5.0 Ownership input
I posted a similar thread in the 50th LE forum. After thinking about it, maybe it is be better to ask the larger 2015-2017 Coyote 5.0 M6G Community about ownership experience, since these were the "intro" S550 5.0's that went through most of the growing pains... This thread may also help perspective buyers of a 2015-2017 S550 5.0.
For ONLY the 2015-2017 S550 Coyote 5.0, please add your Ownership experiences here, being that the vehicles have now aged 5-7 years after production.
1) Basic -
- How many miles on your 2015-2017?
- Daily driver, Garage Queen or Race (Drag/Road/Auto Cross)?
- Long term ownership experience to date as far as reliability and expectation?
2) A/C System -
- Any issues with the A/C or common EVAP core problems?
- If problem, was it the A/C compressor or EVAP that failed?
3) MT82 -
- Any issues with the gearbox operation or shifting functionalities?
- Any issues with clutch slave cylinder?
4) 6R80 -
Any issues with harsh shifts or valve body concerns?
5) Engine -
- Oil consumption issues?
- VCT issues?
- Intake (IMRC) issues?
- Water pump issues?
- Timing system issues (chain, guides, etc.)
- OPG issues?
- If engine has been replaced, why?
6) SYNC -
- Have you upgraded your 2015-2017 SYNC to the most current version available for 2015-2017?
- Have you upgraded SYNC to the 2018+ SYNC? Upgrading to the 2018+ may require swapping of the APIM or other components.
- Have you added Apple CarPlay/Android Auto?
7) Paint/Corrosion -
Any issues with hood (rust, corrosion or peeling)?
Any issues with corrosion in drainage channels at front windshield or rear window?
8) Has anyone tried to add the 2018+ Active Exhaust?
VisceralSyn
Memphis, TN
David
2017 Ford Mustang GT
2017 Ford Mustang GT base, purchased in sept 2016
Basic:
60K miles
Daily, Auto-X*1, Dragged*1, Road Coursed*5+, garage-queen
A/C:
no issues, yet..
MT82:
High RPM lock out, once, at the road course, was going from 3rd to 4th... may have misshifted too
6R80:
*giggles*
Engine:
Oil changed every 5K miles, 1qt oil consumed when using synthetic blend, no consumption with
full synthetic
IMRC gave up the ghost at 35K, was still under warranty
Sync:
What is that?!?!? Base !!!
Paint:
Dealership damaged front bumper, they had it repainted, looks like ripe sh*t...
no corrosion
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
1) Basic - currently 11,3XX miles, total garage queen and weekend fair weather toy since Day 1. Has been my favorite Mustang to date, even above the special edition cars in my sig. I'll probably keep this one since I have no desire for an even more complex and more expensive fun car, I'll buy older to add to the fleet. Fit and finish are my only real gripes with mine.
2) A/C System - none, knock on wood
3) MT82 - trans was "nibbly" when cold until a BG fluid swap, flawless since
5) Engine - used a little oil at first despite aggressive break in, settled in around 5,000 miles
6) SYNC - no on all
7) Paint/Corrosion - no issues, but the car lives indoors and doesn't see rain
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
2017 Mustang GT 300a car with one option (mandatory block heater) ordered new;
~ 45k
~ 3 season daily lots of drag racing
~ Long term no complaints
~ a/c no issues
~ MT82 w/ original clutch / slave no issues
~ original engine with no issues
~ base radio no issues
~ paint/corrosion no issues
~ no
S550_GTCS
Morris County, NJ
Shawn
2016 Mustang GT CS
2016 Cali Special
1. 49K miles
Daily driver
2. AC is blowing strong
3. MT-82 is fine.
5.Very little oil consumption (.5 qt every 5K miles)
6. lost audio for navigation. failed update with USB. No plans on having it fixed
7. hood was bubbling at 25K miles. instead of having ford fix it, I bought a cervinis hood.
bnightstar
Bulgaria
Hristofor
2013 Ford Fiesta 1.25i, 2017 GB Ford Mustang GT PP Premium
1) Basic -
34820 km (21626 miles)
Daily/Time Attack car
Issues I have with the car: Driver side rear wheel hub (number of times), MT82 oil leak (fixed), Rear suspension clunk overbumps (still ongoing issue), squeeking rear springs (but this is normal), Clutch slave cylinder gone.
2) A/C System -
Works amazing. No Issues.
3) MT82 -
2nd to 3rd gear locks besides that shifting is fine. Issue was an oil leak last season.
Slave cylinder is gone but was probably due to air and not bleeding clutch during brake system brake fluid changes or Motul RBF660 to much for slave cylinder. Replacing clutch with Exedy Mach 500 still waiting on Parts.
5) Engine -
Had issue with oil consumption but was fixed with an ECU flush to newer version by my dealer.
- VCT issues?
none that I know about.
no issues
no issues
no issues
- OPG issues?
no issues
6) SYNC -
Nope don't care don't bother.
Have it by default MY2017
No but I have XPEL on it since new.
Never checked. Hopefully not.
Snook66
'17 GT Grabber Blue
Only issue so far is the paint....it's awful. popping off around rear glass and windshield. I believe it will chip off of the front if a cotton ball hits it.
Any pics of this? Is the seam sealer cracked and so you know if you're having any water intrusion?
charlied
Minneapolis, MN
2012 Escape Limited
2017 gt/cs
28,350 miles, manual
Daily driver from spring to fall weather permitting
Only issue is paint chipping off the edges of the mirrors
gamecoc430
South Carolina
2017 Mustang GT Premium
2017, 401, A6, 28,000 miles, daily driver 12 mo a yr, car is/has been perfect since new except for one issue. Sometimes would not start (engine cranks but not firing up). Took a while to find the problem but to correct it the entire inside brake pedal system was replaced, no issues since. This has been my best Mustang ever and I started with a 1965, 1968, 1971, etc! Gaps on doors, hood, trunk are perfect and even, paint (Ruby Red) is perfect, no bubbling or corrosion anywhere. Guess I must have one of he best assembled 2017 Mustangs ever!
johnscousin
Salisbury, NC
Jim
2017 LB Mustang GT PP
2017 GT 301A with PP.
44,500 miles
The only issue I've experienced was the driveshaft vibration issue. It's still there after several trips to the dealership, but it is much better. The car has been flawless other than that.
jc
2morrow
DesignR/DriveR/RiceEatR
NorCal Bay Area
Todd
'16 Mustang GTPP
Great idea, here you go.
1) Basic:
- 50K
- Garage Queen/Track Car
- Very Reliable with very little maintenance issues. However I ALWAYS inspect and work on my car.
2) A/C System:
- No issues at all
3) MT82 -
- No issues at all but it is a whiny gearbox. Sounds like straight cut gears at times lol.
- Sidenote: I use high grade trans fluid and change it every other season. I also have a Barton V2 Shifter.
4) 6R80 -
- N/A
5) Engine -
- No Oil consumption issues
- No VCT issues
- No Intake (IMRC) issues. Upgraded to a ported unit years ago.
- No Water pump issues
- No Timing system issues (chain, guides, etc.)
- No OPG issues. OPG and CS were changed to forged units years ago.
- No engine replacement yet
6) SYNC -
- Originally had a 4" unit but upgraded it to a 8" aftermarket unit.
- Contemplating either ripping the whole thing out or replacing it.
- No paint issues. live in CA and garaged.
- No drainage issues
8) I have a fully custom exhaust but not active.
Overall, it's a great car and has given me a great ownership experience.
kluke15
Reno, NV
Kenny
2017 Mustang GTPP
2017 gt perf pack car. 45K miles, daily driver, only actual issue i had was my left rear axle retaining nut backed off a little causing a clicking noise, tightened with locktite and no issue since. paint is thin and thats my biggest complaints is rock chips appear easily. dragged a couple times without issues. no issues with MT82 or clutch, shifter was a little sloppy but MGW fixed that. really no other issues. been a great and reliable car for the almost 6 years ive had it.
Rock&Roll
New York
2016 GT Stick- 2022 VW GTI Stick -2011 HD Fatboy
1). 2016 with 25k
I have 4 vehicles thats why it has low miles.
2) AC compressor went bad :(
3). No issues with the MT 82
4) n/a
5 ) Engine runs great
6) I upgraded Sync 3 and changed USB port to get Apple CarPlay
7) Paint is fine
8) I’m good with MBRP street exhaust I installed.
