2015-2017 S550 Coyote 5.0 Ownership input
RalphK
Central Ca
Ralph
2020 GT PP2
2016 111,000 miles
No typewriter tick, doesn't burn oil. Have not fixed one thing, Never babied.
Only tires, brakes and fluid changes.
My 2020 PP2 burns a little oil and has more engine noise but nothing out of the ordinary, only 5000 miles on her.
kaibab
Wylie Texas
Don
2016 mustang gt convertible California special
No big issues here except rear camera wiring in trunk and replaced camera. I performed work myself. 37,000 Occasional weekday and weekend use.
luisfe_5.0
Mexico
Luis
Mustang GT 5.0 2017
1) Basic -
- How many miles on your 2015-2017?
25k miles
- Daily driver, Garage Queen or Race (Drag/Road/Auto Cross)?
Daily driver
- Long term ownership experience to date as far as reliability and expectation?
Good!
The only problem I had was the steering rack, It stopped working,
the DTC was: U3000:49-8B
2) A/C System -
- Any issues with the A/C or common EVAP core problems?
No,
- If problem, was it the A/C compressor or EVAP that failed?
No
3) MT82 -
- Any issues with the gearbox operation or shifting functionalities? N/A
- Any issues with clutch slave cylinder? N/A
4) 6R80 -
Any issues with harsh shifts or valve body concerns?
When its cold sometimes shift harsh 2-3, no problem when it gets warm the 6R80.
5) Engine -
- Oil consumption issues? No.
- VCT issues?No
- Intake (IMRC) issues?No
- Water pump issues?No
- Timing system issues (chain, guides, etc.)No
- OPG issues?No
- If engine has been replaced, why? Not remplaced.
6) SYNC -
- Have you upgraded your 2015-2017 SYNC to the most current version available for 2015-2017? Upgraded to 3.0
- Have you upgraded SYNC to the 2018+ SYNC? Upgrading to the 2018+ may require swapping of the APIM or other components. No.
- Have you added Apple CarPlay/Android Auto?
Already had it
7) Paint/Corrosion -
Any issues with hood (rust, corrosion or peeling)? No
Any issues with corrosion in drainage channels at front windshield or rear window? No
HoosierDaddy
Randy
2016 GT Premium PP
Did a Ford dealer give you the parts to DIY? Or were the parts cheap enough to avoid risk factor of dealer possession of car?
There was a Ford dealer employee who claimed there are provisions in the warranty for owners to get parts for DIY if diagnosed or recall. He's long gone from the forum though. And dealers obviously don't want that to happen because they won't get paid for labor.
I notice you mentioned camera. I understand the original recall was just related to wiring but the latest replaces the camera and cable. If you did it yourself, were you forced to replace the camera because the new cable doesn't work with original camera or was a new camera worth buying if all was done on your dime.
kaibab
Wylie Texas
Don
I used commercial door security wiring butt style connectors where the trunk lid camera wiring was pinched. I decided to replace the camera thinking it might of taken a hit also. Mine failed before the ford recall came out. Wish i had waited till that happened. Now i hear the mini circuit board in the camera is failing because of bad solder welds.
RookieDDZ
Central New York
Brian
2017 Mustang GT
Yeah, I'm still trying to get the latest info on it. My camera and cable seem to be fine, but I rather be ready and correct any issue now before it breaks. Plus I rather do all the work myself.
Howitzer
NC
flickr.com
Howie
2015 Mustang GT, 2000 Mercedes C280
Just to add to the list...
Owned car since 2015.
1) Basic -
-52k miles
-Used to be daily driver, then a few days a week car, and now road course car and occasional weekend/trip.
-Only mechanical issue I've had is a rear main seal leak at 48k miles. Car has been very solid and reliable including for track duty.
Driver-side rear diff bushing also started to split some. I believe this started after I started tracking the car. I added whiteline bushings to help with this.
2) A/C System -
-No A/C issues at all yet.
3) MT82 -
-No real issues. I did experience some tougher than normal shifting from 4th to 5th at VIR. I replaced shifter with an MGW and no further problems; very smooth shifting now.
4) 6R80 -
5) Engine -
- Oil consumption issues? No oil consumption at all.
- VCT issues? None
- Intake (IMRC) issues? None
- Water pump issues? None
- Timing system issues (chain, guides, etc.) - None
- OPG issues? None
- If engine has been replaced, why? Original engine.
6) SYNC -
I got rid of SYNC entirely and run an android radio.
Any issues with hood (rust, corrosion or peeling)? None
Any issues with corrosion in drainage channels at front windshield or rear window? None
8) Has anyone tried to add the 2018+ Active Exhaust?
Negative
HoosierDaddy
Randy
2016 GT Premium PP
Its possible Ford will reimburse for repairs done before the recall. If so, they might hand you a new camera.
kaibab
Wylie Texas
Don
34 K miles with no mechanical issues yet. Added no light style bar with wind deflector. Love this drive.
FUN2RIDEFAST
Ofallon, Missouri
2017 Mustang GT Premium/PP
2017 mustang performance pack Roush Phase 2 supercharger. Daily driver. Retired. 43,000 miles and zero issues.
