2015-2016 Tech Pack and Base GT350 Cooler Solution Discussion
16Kobra
2019 GT350R
Ahh, thought you did the work yourself. Understood now:thumbsup:
Wanted too, work got too busy and I have a terrific shop who does the work if I dont have time..
16Kobra
2019 GT350R
Jim and I discussed the pump electrical load. Be sure you use an adequate circuit or just run a sufficient fused tap off the battery.
Jim and I discussed his setup. He knows what he's talking about, pay attention.
Like Tom said, we were talking thru the entire weekend. My tranny temps were comparable to his thru out the sessions.
I have mine on a switch and have only turned it on for the track events. Have not driven in our Fl heat enough to know if needed. But, through our past summer drove the car alot and never went into limp mode.
Hack
Minneapolis
Mustang, Challenger
Clink
'14 Focus
Contains OEM components found on GT350 Track Pack Does not include pump or transmission with integral pump
Kit Includes:
8C3Z-7Z465-A RETAINING CLIPS
FR3Z-4B496-B BOLT, DRIVESHAFT @ DIFF S550
FR3Z-7A095-C GT350 TRANSMISSION COOLER
FR3Z-7B147-A CORE BRACKET
FR3Z-7D388-A BRACKET, COOLER
FR3Z-7R081-E COOLER LINES, FROM TRANSMISSION
FR3Z-7R081-F COOLER LINES, FROM COOLER
N800594-S101 DRIVESHAFT U JOINT FLANGE BOLTS
TA-25B THREADLOCK & SEALER (LOCTITE BLUE)
W503293-S439 BOLT, COOLER TO FENDER
W505424-S442 BOLT, BRACKET TO CORE
W520103-S437 NUT ALTERNATOR
W520412-S441 NUT
W520803-S439 NUT-HEX
W701014-S441 NUT, TRANSMISSION LINE TO BELLHOUSING
W705443-S900 NUT, MOUNT TO CROSS MEMBER
W709390-S439 BOLT, BRACKET TO BODY
W711390-S450B BOLT, BRACKET TO COOLER
W714182-S442 BOLT, COOLER TO BODY
W716188-S437 BOLT, LINE TO TRANSMISSION
W717822-S439 BOLT, DRIVESHAFT @ BEARING S550
Part Type D-Line: Manual Trans
Warranty Availability: Not Available
UPC: Code756122005828
Country of Origin: United States
Tomster
Beware of idiots
Tom
Hallelujah!!!!
At last, at last!
And IMHO, $695 is a good deal.
arsenalrocks
GTA
2016 GT350
just did some quick calculation, the cooler itself is about 380 USD
2 lines are 170 USD, total ~550USD
the rest of bolts and nuts add up to 140 USD
this is hardly a deal, I bet if you order the parts individually at the big discount vendors it may be even cheaper.
Kit Includes:
W520412-S441 NUT
Epiphany
Global
I like to disassemble things.
can we expect any of the big vendors (autonation bear lack etc) to sell for less?
Most any Ford Performance Parts distributor will be selling for less than retail.
arsenalrocks
GTA
2016 GT350
the more I think about this the more angry I get, took them 1 year and 3+ months to come up with an existing part lists with virtually 0 discount.
Tank
9/11 - Never Forget
Above the Notches
G0853
Hallelujah!!!!
At last, at last!
$695 is list price...waiting on guy to give me retail (or better) price. Will post when I get it if not posted before.
Also, don't forget to add the price of the pump, switch-
Makes me think I'll keep an eye on the SA kit esp if they are also using OEM parts and they offer at least a diagram
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
So, this means we still need to buy a pump, braided hose lines, figure out where to install pump, fabricate holding brackets for said pump, install a switch and wire everything up.
If SA has a complete kit out soon, they might get my business.
Screamer
Fla
Al
2116 GT350
This is ok for installing a transmission with pump. For the remote pump guys The 7R081-E / F lines are useless as are most of the bolts listed. I sorted this last march when I installed the oem cooler and bracket and duct. All afterrmarket from there.
Tank
9/11 - Never Forget
Above the Notches
G0853
Hey [MENTION=22645]Screamer[/MENTION],
Didn't you post your step by step on this forum? If so, could you post the link?
Thanks for your perspective:thumbsup:
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
Like said before, half ass kit if you don't buy the tranny.
