2015-2016 Tech Pack and Base GT350 Cooler Solution Discussion
zombiekiller
warranties are 4 wussies
New Orleans
16 gt350, 66 galaxie,a Tesla, and an AMG G63
Like said before, half ass kit if you don't buy the tranny.
the parts that you need, using everything oem, aside from lines and pump should come to about $390.
This is no deal.
I am torn between finishing up my electric pump cooler or just buying the trans with the pump.
I'm thinking i could use my non-pump trans in my galaxie behind a 5.0.
And then the thought also becomes, if i'm going to swap the trans, do i also get a mcleod clutch just in case?
argh!
Tank
9/11 - Never Forget
Above the Notches
G0853
argh!
One of my considerations in this decision is to give the least amount of additional $$ to FoMoCo...
VOODOO 6G
Ohio
Eric
2016 Shelby GT350
When I get around to it I'll be getting both the tranny and cooler kit. I want as close to factory as I can get.
TDC
Long Island
2016 GT350, 2019 Challenger Scat Pack Widebody, 2019 Corvette Grand Sport
Since Ford isn't going to offer warranty with their kit then I believe a complete kit like what SA is developing is a better choice.
zombiekiller
New Orleans
I'm also thinking that the tech pack trans with an external cooler may actually be lighter that the trans with integrated pump be a few lbs.
I think, at least for the time being, If i'm spending 3 grand on stuff for the car, i'll get a CF hood and Decklid and shave about 30 lbs off the car instead.
16Kobra
2019 GT350R
Guys, The stock lines listed will not work. When I did my kit, the spots for the lines are there with caps in the holes. The holes are not Tapped for installation of the lines. And the front trans line is connected to the internal pump which we do not have.
The shop I used, LaMotta Performance, here in Longwood Fl removed the tail shaft and tapped the stock hole for the return line, but we used the drain hole on trans to drain to the cooler.
I know the Ford kit is OEM looking, but as stated above you still have to buy pump, hose/fittings and switch.
Please thru this link:
http://www.mustang6g.com/forums/showthread.php?t=49659
I used SVTDSM's write up as suggestion and the shop made some mods to his design. I am very happy with the way it came out.
Tank
9/11 - Never Forget
Above the Notches
G0853
[MENTION=23739]16Kobra[/MENTION], can't thank you enough for your info. Based on what you said, it's outrageous, after all this time, the kit would include lines that do not work. :rant::frusty:
Kudos on your design that eliminates the questions about using the drain and fill holes.
Thanks too for the link.
16Kobra
2019 GT350R
I dont want the credit for the design, all that credit goes to [MENTION=7179]SVTDSM[/MENTION]. I used his suggestions and the shop made it work...
Minn19
Minnesota
Jason
19 ZL1 1LE, 19 F150, 19 SB S5
So basically, if you are going to do the track pack tranny and cooling kit together go through FP. If you are going external, go aftermarket. Got it.
Thanks all for the hard work and advice on the issue.
Tank
9/11 - Never Forget
Above the Notches
G0853
I'm thinking of cherry picking through the parts in the kit that'll give me an OEM looking cooler mount..use braided lines with AN fittings and take advantage of Shelby American's research into a "quieter" pump, switch and wiring. Figure the cars in storage until the salt clears so hopefully this will all come together by early March '17.
Agree w [MENTION=24957]Minn19[/MENTION], thanks to all who have pioneered the solution a year before the official kit. :cheers:
arsenalrocks
GTA
2016 GT350
thank you for your comment, your finding essentially renders this no warranty cover kit from FP completely useless.
so disappointed in FP, took a year and 4 months to come up with a kit with no warranty and useless.
This is ok for installing a transmission with pump. For the remote pump guys The 7R081-E / F lines are useless as are most of the bolts listed. I sorted this last march when I installed the oem cooler and bracket and duct. All afterrmarket from there.
Tank
9/11 - Never Forget
Above the Notches
G0853
Contains OEM components found on GT350 Track Pack Does not include pump or transmission with integral pump
Kit Includes:
8C3Z-7Z465-A RETAINING CLIPS
FR3Z-4B496-B BOLT, DRIVESHAFT @ DIFF S550
FR3Z-7A095-C GT350 TRANSMISSION COOLER
FR3Z-7B147-A CORE BRACKET
FR3Z-7D388-A BRACKET, COOLER
FR3Z-7R081-E COOLER LINES, FROM TRANSMISSION
FR3Z-7R081-F COOLER LINES, FROM COOLER
N800594-S101 DRIVESHAFT U JOINT FLANGE BOLTS
TA-25B THREADLOCK & SEALER (LOCTITE BLUE)
W503293-S439 BOLT, COOLER TO FENDER
W505424-S442 BOLT, BRACKET TO CORE
W520103-S437 NUT ALTERNATOR
W520412-S441 NUT
W520803-S439 NUT-HEX
W701014-S441 NUT, TRANSMISSION LINE TO BELLHOUSING
W705443-S900 NUT, MOUNT TO CROSS MEMBER
W709390-S439 BOLT, BRACKET TO BODY
W711390-S450B BOLT, BRACKET TO COOLER
W714182-S442 BOLT, COOLER TO BODY
W716188-S437 BOLT, LINE TO TRANSMISSION
W717822-S439 BOLT, DRIVESHAFT @ BEARING S550
Part Type D-Line: Manual Trans
Warranty Availability: Not Available
UPC: Code756122005828
Country of Origin: United States
Yeah, so I'm going a bit crazy w this kit stuff but I was looking for part number
FR3Z-8310-F. It's the duct that replaces the block out panel.
http://www.mustang6g.com/forums/showpost.php?p=1203787&postcount=65
I do not see it listed in the kit or the word "duct" in the parts description. WTF did we wait for?
Voodooo
SE Michigan
Scott
Carroll Shelbys Soul Lives Under My GT350 Hood
Ford performance sucks. Talk about a let down! I feel for the base and tech owners!
lemers
Globetrotter
Carlisle, PA
2016 GT350
It seems like this was a fire and forget model. I fear that there will be very little in the ways of support for the GT350 from FP.
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
It basically took FP 1 day to put the incomplete parts bin kit together and 1 year 4 months to do the marketing. Way to go Ford ? :thumbsup:
