18+ GT Performance Tune Pac
RoGCobraRV
Jacksonville, FL
2020 Mustang GT
Thans man! He sent me a pm but at least I know how now.
geep81
Cleveland OH
2020 GT Premium
The gt350 and bullitt owner's manual say about 30k. I have about 10k miles on mine and it's looking dirty but the car doesn't notice. I'll probably take it off and pound out the bugs then run it for another year.
Thanks! And very nice car you got. 👍
UTAR15
Las Vegas, NV
2020 Mustang GT Prem
asc709
El Paso, TX
Robert
2020 Mustang GT Premium PP
Still giving out group codes? I want this!
wa9njm
Upstate SC
Nick
2019 Mustang Bullitt
If codes are still available I'd like one too. Thanks.
NeedForGreen
2019 Mustang GT
Does anyone know what air/fuel ratio this tune should be running at? I think I may have an issue with the throttle body sensor or something else like an O2 sensor. Cars not tossing any codes. I usually see 14:1 at idle and 12:5 ish on wot. Now I'm seeing nothing change on wot. Doesn't drop. But then I'll see it go to 13:9 and as high as 15:1 when cruising. That definitely concerns me.
EFI
Masshole central
5.Br0
Fueling is not changed with the tune over stock, they both run the same exact lambda. The formula is stoich (14.08) * lambda, so at full throttle you should be in the mid to high 11s AFR.
Have you logged it throughout a WOT run to see that it doesn't go into power enrich? It takes a bit of time to get into it, it's not instant and it's only at full throttle eg. 90%. If you're not quite at full throttle, it won't go into power enrich and you'll see near stoich values.
Also during cruise it will fluctuate more, 15.1 is nothing to be concerned about. But if you're WOT at high rpm and it doesn't get into the 12s or less then you have some issues. Although at that point you would throw lean codes and/or other sensor codes like MAF or WB etc.
