2015+ S550 Mustang Forum (GT, GT350, GT500, Mach 1, Ecoboost) - Mustang6G.com 22 - Velgen Wheels - 1
Homepage Wiki MOTM Register Search Today's Posts Mark Forums Read Ford Bronco Forum Calendar Garage
Go Back   2015+ S550 Mustang Forum (GT, GT350, GT500, Mach 1, Ecoboost) - Mustang6G.com > 2015+ Ford Mustang Forum > Mustang S550 General Forums
Mustang S550 General Forums General topics related to the S550 6th Generation Ford Mustang
User Tag List
Reply
Thread Tools Search this Thread Display Modes
Old 02-12-2018, 10:18 AM   #1
EastTNMustang
EastTNMustang's Avatar
Drives: 2017 Roush Stage 3
Thanked: 69 Times in 41 Posts
iTrader Score: 0 reviews
FORScan Codes - S550 Mustangs
I've been reading several FORSCAN-related threads on this Forum (it's been raining a lot in East TN) and have not seen a single-point collection for all the FORSCAN Codes available to us S550 owners (look at the Fusion or F-150 Forums and you will see they have a great collection of FORSCAN codes for their platforms.)
So to that end, I'm putting together a spreadsheet which shows the FORSCAN codes we may be able to use to modify/customize our S550 rides. Please bear with me as I continue to update this thread with the spreadsheet (I'm still reading multiple threads collecting the info and I know there are updates for Speedo corrections, tire sizes, etc.)
THANKS and credit goes to: @DanMc85 , @AngelDeath , @fionic , @Spart , @Epiphany (and many others) for all the ground-breaking work they've done to track down these codes and help others to learn about FORSCAN. I'm just here to collect the info in one place and make it easier for us to track the codes.
Please post on this thread (or PM me) any new codes or corrections that you may have...it is helpful if you post/PM the code change in the following format (this is an example): IPC 720-01-01 xxxx 1xxx xxxx - default/as built data, IPC 720-01-01 xxxx 5xxx xxxx enabled , then a Description of what change did.
NOTE: This thread is not intended to answer questions such as: What is FORSCAN? Where do I download FORSCAN? What OBD device should I get? etc. Please use the Forum's search function for those type of questions. This thread should be to add/correct/remove FORSCAN codes that affect our S550s and to answer questions of what some of the codes/functions change in our vehicles.
https://docs.google.com/spreadsheets...it?usp=sharing
__________________
SMR #8017
EastTNMustang is offline   Reply With Quote
Old 02-12-2018, 12:54 PM   #2
poncho@home
Drives: 2017 Mustang GT Premium
Thanked: 48 Times in 33 Posts
Thanks! I got to start looking into Forscan as well.
__________________
2nd midlife crisis: 2017 Mustang GT Premium, Magnetic, 6spd, Blk app pkg.
1st midlife crisis: 2004 BMW 330Cic, Silvergray, 6 spd
Family hauler: 2013 Audi Q5 3.0t S-line
Commuter/winter beater: 2011 Subaru Legacy Premium, 6 spd
poncho@home is offline   Reply With Quote
Old 02-12-2018, 03:37 PM   #3
EastTNMustang
Updated with the following:
Stereo Extended Play - Adjust how long you want your radio to play before turning off
Secure Idle (Automatics only) - If car is running and you remove the fob, shifter can't be moved from Park
Turn Signal - # of flashes for lane change - if you quick/temporary move turn signal indicator, you can modify how many flashes before it turns off
VIN # - where to see the VIN # in the BCM Module
__________________
SMR #8017
Old 02-12-2018, 04:09 PM   #4
DukeGaGa
DukeGaGa's Avatar
Drives: 2018 Mustang GT Premium PP
Thanked: 170 Times in 106 Posts
Is it possible for ForScan to modify things in the lcd dash? If so I might start digging into that.
__________________
2018 Mustang GT Premium Fastback - 6MT - Lightning Blue - Midnight Blue Interior - 401A - Shaker Pro - Enhanced Security Package - Safe & Smart Package - Performance Package - MagneRide - Active Exhaust
DukeGaGa is offline   Reply With Quote
Old 02-12-2018, 04:20 PM   #5
Fordever
Fordever's Avatar
Drives: 2016 GT/CS Vert
Thanked: 701 Times in 518 Posts
Should this be a sticky????? Maybe????
__________________
Fordever is offline   Reply With Quote
Old 02-12-2018, 04:44 PM   #6
5pointOh
Drives: 2016 Mustang GT PP @falcon_S550
Thanked: 155 Times in 124 Posts
I'm guessing you missed this whole thread where this is already taking place?
https://www.mustang6g.com/forums/showthread.php?t=96464 Might want to get with @Spart if you have anything he doesnt have already.
5pointOh is offline   Reply With Quote
Old 02-12-2018, 06:29 PM   #7
Gman
Gman
Gman's Avatar
Drives: 2016 Magnetic Mustang
Thanked: 220 Times in 117 Posts
iTrader Score: 3 reviews
X2 I was about to say the same thing.
This is the real Forscan thread that is sticky in DIY section. It has almost everything that can be done. Some not listed but those are on the F150 spreadsheet
https://www.mustang6g.com/forums/showthread.php?t=61773
__________________
Gman's 2016 A6 Magnetic 5.0 GT
Beith Performance Parts GT350 Carbon Fiber Style Steering Wheel
Forgestar CF5 Front 20x9, Back 20x10.5
Corsa Extreme Black Tip
Eibach Sportlines
Steeda Stuff: Strut Bar, Extreme G-Trac K-Member Brace, Adj Rear Toe Links, Adj. Camber Arms, Billet Vertical Links, IRS Subframe Support Braces, Jacking Rails, and Adjustable Differential Bushing Insert System - Urethane (Red)
Gman is offline   Reply With Quote
Old 02-12-2018, 08:13 PM   #8
EastTNMustang
Iíve seen that thread and from what Iíve read, the thread you listed is for gathering as many data points (as-built info) as possible to help in deciphering the codes for FORSCAN. The list Iím putting together is for people who are familiar with FORSCAN and want to look up specific changes they can make...all of those changes listed in one document.
__________________
SMR #8017
Users thanking this:
Old 02-12-2018, 08:19 PM   #9
EastTNMustang
Funny you list this thread...this is what got me thinking about gathering all of the FORSCAN changes in one easily accessible thread.
Have you read the entire 151 pages? LOL It seems that a couple of lists were started in that thread, but then stopped. Iím collecting those FORSCAN changes, and other changes from 3 other forum threads (along with reviewing the F150/Fusion/Explorer/Expedition forums) to have one document that lists those changes.
__________________
SMR #8017
Old 02-12-2018, 10:43 PM   #10
D24112
D24112's Avatar
Drives: 2017 V6 MT
Thanked: 41 Times in 28 Posts
I have read all 151. Please complete the list.
D24112 is offline   Reply With Quote
Old 02-12-2018, 11:12 PM   #11
fionic
spaghettios and cheerios
fionic's Avatar
Drives: 15 GT PP
Thanked: 599 Times in 351 Posts
Quote:
Have you read the entire 151 pages? LOL It seems that a couple of lists were started in that thread, but then stopped. I’m collecting those FORSCAN changes, and other changes from 3 other forum threads (along with reviewing the F150/Fusion/Explorer/Expedition forums) to have one document that lists those changes.
please see the spreadsheet in my sig. there may be a newer one that someone else has made since in the diy thread already posted (also in my sig). reminder that these are control module value changes, not really codes.
__________________
P8C/HN/51/400A/53H/99F/44X/67G/12A/43S/68B/91N
S550 AS-BUILT VALUES
THREAD, HOW TO USE AS-BUILT VALUES
fionic is offline   Reply With Quote
Old 02-13-2018, 03:40 AM   #12
MakStang
MakStang's Avatar
Drives: A 2017 miraculous little beast
Thanked: 175 Times in 149 Posts
I have the impression that @EastTNMustang ’s spreadsheet is a bit more up-to-date.
__________________
2017 EU Mustang EcoBoost PP, AT, Race RedMBRP Race Catback Exhaustscp-e DeltaCore intercoolerCobb Accessport V3Unlimited Tune by Tune+ with multiple slots: 93+ oct (100 RON) / 91 oct (95 RON) / Eco Transmission Tuning by Tune+NGK 1-step colder Spark PlugsTune+ WGAGFB DV+ BPVAIRAID Modular Intake TubeK&N pre-oiled drop-in Air FilterDD Switchback Tribar DRL LED BoardsUS style red tail lights with amber sequentialDD Smoked Side Markers25mm Eibach wheel spacersSport steering wheelGT35R rear spoilerSide rocker decalsFront grille "Stanginator"
MakStang is offline   Reply With Quote
Old 02-13-2018, 06:29 AM   #13
EastTNMustang
Quote:
Your beginning work on these FORSCAN changes (your second signature spreadsheet) is what started me on this collection effort. AngelDeath's thread and you taking on the initial collection is nothing short of great.
As that thread progressed, more and more codes (changes) were noted but did not make it onto your list (your first signature spreadsheet.) Nothing wrong on your part, we all get overtaken by events sometimes.
After reading the 151 pages I thought I could help the Mustang 6G community by collecting this information (along with the GT350 data) and place it on page 1 of a FORSCAN titled thread...so when folks use the Forum search function they would be able to find the info quickly.
I hope I haven't stepped on any toes doing this project...I'm retired and have a lot of time on my hands, so just trying to help.
Thanks.
__________________
SMR #8017
Old 02-13-2018, 06:31 AM   #14
EastTNMustang
Quote:
I'm paddling as fast as I can
A lot of posts to sift through...for the third time
__________________
SMR #8017
Old 02-13-2018, 09:50 AM   #15
D24112
D24112's Avatar
Drives: 2017 V6 MT
Here is one I've been looking for..
"I installed a set of switchback LED turn signals recently, love the new lights, quickly got tired of the hyper-flashing indicator in the car. Santa brought me an OBDLink MX and I got Forscan installed and licensed. Today I tried my hand with Forscan and got the hyper-flashing turn signal indicator turned off.
727-27-01
Before: x1xx xxxx xxxx
After: x0xx xxxx xxxx
I found the info here: S550 Guru - Disable signal hyperflashing and can confirm it turns off hyper-flashing on my 2017 GT premium. Someone else posted this link earlier but I couldn't find the post to thank them.
Forscan is an interesting tool, I plan on playing with it some more in the future. To all the pioneers who blazed the trail, a big hat tip....
__________________"
Plagiarized and Courtesy of catchthecarp
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
ZL1 Addons & S550 Carbon Discount Codes 50 Deep Cosmetic/Visual Mods (Exterior + Interior) 3 02-26-2018 06:51 PM
Ford Paint Codes & matching Pantone Codes MF_AutoDesigns Cosmetic/Visual Mods (Exterior + Interior) 1 10-04-2017 01:48 PM
2017 Mustang gt got a couple codes car is acting weird ochoa455 Issues, Repairs, Warranty, TSB, Recalls 3 05-30-2017 10:07 PM
Diode Dynamics Tail light Sequencers throwing error codes on FORscan rvlyssup Cosmetic/Visual Mods (Exterior + Interior) 2 12-06-2016 01:54 PM
DTC codes p0420/p0320 on a new Mustang GT Andyjamo1961 Mustang S550 General Forums 8 05-05-2016 09:01 AM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging v3.2.4 (Lite) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.Navbar with Avatar by Motorradforum
Garage vBulletin Plugins by Drive Thru Online, Inc.
