Vibration between 50 & 70 mph - What fixed your problem?
What fixed your vibration between 50 & 70 mph?
  • Drive shaft replaced with another factory driveshaft
    Votes: 2 6.1%
  • Drive shaft replaced with aftermarket one-piece unit
    Votes: 0 0.0%
  • Differential or related components repaired or replaced
    Votes: 5 15.2%
  • Half shafts replaced
    Votes: 0 0.0%
  • Transmission or related components repaired or replaced
    Votes: 0 0.0%
  • Other
    Votes: 7 21.2%
  • Nothing
    Votes: 20 60.6%
  • Total voters
    33
icarumba
Mount Juliet, TN
Mopar or No Car
If you are one of the lucky ones who have had your vibration between 50 and 70 mph fixed, what was the solution? If you had multiple repairs done, only check the one repair that fixed the problem.
NOTE: Often the vibration will return, so please hold your vote on the solution until you have driven a couple thousand miles without problems.
If you want more information on this topic, go here: http://www.mustang6g.com/forums/showthread.php?p=787049#post787049
speedfrk
Atlanta
www.nationalsuperbike.com
Curt
2023 F150
Maybe let people vote on what fixed theirs and add another option "vibration came back" so we at least know what initially fixed it. If it comes back, that is also good info since it suggests a recurring part failure.
icarumba
icarumba
Mount Juliet, TN
Mopar or No Car
Good idea, but it doesn't look like I can edit the poll after voting has started.
5 O UFO
Super Moderator
Moderator
Ohio
Brian
2017 GT Premium Convertible
Drive shaft re-indexed at rear flange to align marks.
stiracer
Ellenton Fl
2015 comp orange Premium pp ecoboost
first cool morning when I hit I-75 soutbound with less than 2 miles slow driving before getting there I experienced a vibration @ 60 or so to 80 or so. Turns out the weather warmed up and it was only tires were flat spotted overnight with the cool temps.
768mph
Virginia
2021 Mustang GT
Bumping this thread so others can chime in.
joedrt73
georgia
2016 mustang gt base coupe
Ford bought mine back after they replaced everything in the driveline including the rear differential.
888mustang
Albany NY
Bill
2015 Mustang V-6 051A 6spd,95 Mustang GT Vert
Had drive shaft replaced,no difference.Changed clock position on rear drive shaft to pinion flange (re indexed) 3,000 miles ago vibration gone or 95% gone.
Tried 5 different positions,makes a HUGE difference.
JakePSD
Ohio
2017 GT Premium Performance Pack
Figured I'd bump this back up to the top. I have the vibration and I'm super paranoid about letting the dealers touch my car. Every time I've had it in for anything it comes back damaged, so I'd like to fix it myself, and just looking for what the most likely cause is.
Gurjit
B.C. Canada
2016 GT Premium performance pack
Visiting the dealer tomorrow to show the service manager what my car feels like on the highway. He road tested my vehicle after hey replaced the driveshaft and said its good.
It is way worse and it hums around 86 kmhr.
We will see what he says.
Unfortunately for him iam a dignostic tech and have access to a vibration analysis tool and software which i have alot of experience using.
Also noticed a water leak in my trunk spare tire well that needs to be looked at.
JakePSD
Ohio
What exactly is the procedure to square everything up? I'm gonna be jacking mine up in a week or 2 to have a look and want to fix this problem. Probably a dumb question but when I'm messing with my $40k plus baby, I wanna make sure I do it right.
scrubber3
Hopper, is that you?
Sandhills NC
2017 GTPP Shadow Black. 2001 Jeep XJ 4x4
GregO
Illinois
S550 GTPP
Steeda alignment dowels and a shop that understands thrust angle and how to correct if necessary.
Cruizer40
Bonney Lake Wash.
Bryan
2016 Mustang GT California Special, FPP2
New driveline and rebuilt rearend. A dealer that I'd familiar with the issues helps as well.
