GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
Rather than showcase my car, I chose to focus my build log on tips and techniques for mods and service.
Master link list to my more helpful posts. New posts added will display NEW.
ALIGNMENT
Multi-part series on DIY methods for measuring and adjusting your car's alignment
At-home method for measuring camber
At-home method for measuring toe with Toe Plates
Tips for easily adjusting Camber and Toe between street and track settings
Review of Rear Camber Adjustment Kit (Steeda or J&M camber arm brackets)
My DIY Wheel Cribs
Additional information unique to Steeda camber plates
DIY Camber gauge for Steeda plates
Slotting the strut for more camber
I notched the strut tower hole instead of using hole saw (many pics)
PARTS I HAVE DESIGNED
Brake Air Vanes
Radiator Gap Blockers
Hood side vents
PP1 splitter winglets
MODS & DIY
White Madness shifter
Installing new magnetic paddle shifters - tips & photos
Swapping wheel studs using a ball joint press
DIY cradle lowering studs kit
Changing seat cushion angle with leveling washers (for tall drivers)
Replaced single with dual horn
DIY brake bleed catch can
How I improved the B&O sound quality for free
Join me in fixing the center speaker issue
NEW Ronin oil drain valve, modified adapter drain tube, drain straight into jugs
Spherical bearings everywhere
GT350 brakes and knuckles
GT350R F&R bars
GT500 CFTP front springs and Steeda camber plates
Viofo A229+ 3-cam Dashcam
Clear film scheme
Ecoboost vents in bumper corners
TIPS
Replaced OEM end screws at top of bumper with 7mm screws
Mocked up parts to check wheel fitment on the GT350 calipers, front and rear
Tips to remove LRCA (needs photo)
Rebuilding IRS (This thread has excellent scheme for all four diff through bolts)
Tip about popping that ball joint loose
Add a little post as a ground test point by the interior fuse box
Redline brackets changed for 2018+ cars
Install tips on --> Ford Performance Knuckle To Toe Link Bearing Assembly?
Removing Magneride shock tips
Tips on installing front diff bushing insert pucks
Clunk when first applying the brakes
Outerwears pre filter on Injen Evolution Cold Air Intake
Checking A10 transmission fluid level, tips & photos
https://www.fordservicecontent.com/Ford_Content/videos/WorkShopManual/V34.mp4
Painting my RTR-style front splitter
Better method for tightening strut nut
Better access to bumper end nuts
Pushnuts at bumper ends (keeps bumper tab screws in place during assembly)
Screws at front lower fender liners replace the plastic rivets
Solution to mounting ZL1 rock guards
Access to RLCA big bearing via toe link
Roll pins on OEM toe link adjuster
Leave belly pan on bumper and remove both as one assembly
My solutions to issues with Redline hood struts on a MY2018+ car
Checking wheel runout with HF dial indicator
TOOLS
Drilled caliper pin punch
Five Bananas brake spreader
My Quickjack mods
How I chose Quickjack 7000TL
QJ wood insert panels, new puck tags, and rollers
Pinch weld pucks for my Quickjack
Parking brake cable retainer (WTF)
24mm ignition wrench for turning front tie rods (see Tips for easily adjusting Camber and Toe between street and track settings)
Long 16/18 gear wrench for tightening rear camber arms (see Review of Rear Camber Adjustment Kit (Steeda or J&M camber arm brackets))
Tie rod end tool for pressing out wheel hub studs (see Swapping wheel studs using a ball joint press)
Anti-freeze and brake fluid testers
Adjustable wrench for AN hoses
FLUID COOLING
My DIY oil cooler build
DIY sensor port in sandwich plate
My Diff Cooler Build
Diff temp, stickers, gauge display, Kobalt fan (prior to diff cooler)
Changing diff oil procedure
Starting post for my DIY trans cooler (Needs new writeup of trans cooler)
Oil viscosity chart
Radiator fan shroud ventilated and coolant ratio changed
AIR COOLING
Brake Air Vanes
Hood side vents
Opening OEM grille cells with router technique
Right side Velossatech Bigmouth
HEAT WRAP
Heat wrap my starter
Heat wrap exhaust
Heat wrap battery
Heat wrap on diff cooler pump
TRACK DAYS
Hauling everything to track day
Seatbelt doubler for securing wheels in the back seat
Installed Schroth 4-point harness and Hans
Cut down headrests to half thickness for more helmet clearance
6” cotton wrist bands made my Hans more comfortable Needs photo
Installed Schroth anti-sub belt for use with sofa seats
Interior camera mounted to headrest
Annual cost of tracking my Mustang
Enabled Performance Shift Indicator for A10
GTP
GTP
Deutsche Pony
Indy
Philip
My third brake light says Poor Man’s McLaren, because I have been a McLaren fan since the CanAm days of the ‘60’s. Plus it is Orange Fury with blue stripes.
Otherwise, my car has no name and no gender.
I don’t enjoy detailing my car, but I like the result. There is no “grain” to any of the body panels when I wash it. I don’t post an apology for my car being “filthy” when there is just a little dust on it.
I never say I love my car (although secretly I do). I can’t help it, but it has become part of my identity. Mustangs are a great anti-depressant.
I still get a kick when a little boy holding onto his mom’s hand stops and points at my car.
Making this vinyl overlay was a lot of work and took four attempts.
What little boys turn to stare at. (It's the color of course, but I think deep down they already recognize a sports car.)
GTP
GTP
Deutsche Pony
Indy
Philip
Background of acquiring my second Mustang. TLDR – Traded my 2016 GT for 2019 because all the great new features were not available when I got my first Mustang in Fall 2015. Will update with a longer story later, but mainly the 2018+ cars had so many improvements over the 2017- cars. For example, more gears, 3.55 diff ratio, rear wing, safety radars grouped together, digital dash, adaptive cruise, auto wipers, PP with auto combo, louder exhaust, more HP, better sounding stereo, etc.
And I tested every feature out on the 200 mile drive home from a small town dealer in KY. Big smile for sure.
Photo of my "starter" Mustang, a 2016 Premium non-HP A6 in triple yellow with grabber blue strips, and the new car.
Finally - Here is my secret to finding new Mustangs.
GTP
GTP
Deutsche Pony
Indy
Philip
Six links updated in Post #1. Look for NEW in the TIPS section.
