Caballus
No, not a mountain out of a molehill. You asked, "where is the outrage" for Pres Bush political appointees being recalled. The answer is there should be no outrage, because it is standard procedure and not a procedure that has anything to do with this situation--AMB Yovanovitch is not a political appointee and was not part of that recall.
You also said that Pres. Trump did not do the same, which is not true. Per his prerogative as president, he recalled all political appointees and went a step further by not extending any or allowing for transition time. This also didn't affect the Ambassador to Ukraine, as she is not a political appointee.
So, when placed into context, the statement is wrong, irrelevant, and misleading.
Neither a mountain nor a molehill, just fact.
It's good that the system is working as it should. Based on the comments you made about Ambassador Yovanovitch, recommend you look at her opening statement as well--not Q&A.
Them meeting, right or wrong, has no bearing on the charges the whistleblower made. The whistleblower is not and should not be the issue in the eyes of the American people. The issue here is that the President either did or did not, himself, do something wrong no matter how the possibility came to light. He either did or did not improperly engage a foreign government with the intent of involving them in the American democratic process. The IC IG felt there was enough of a possibility to raise the issue for further consideration.
Regarding firsthand knowledge, the whistleblower was provided the transcript of the call in the course of his responsibilities. That, the IC IG determined, constituted first hand knowledge.
So, you are correct. Context matters.
