barkingspud
- Aug 29, 2019
- NW burbs of Chicago
- Mark
- 2019 Mustang GT Premuim
Depending on boost level 700-860
yes, see my response. Street radials aren't going to reward you very much (forward) with a wider tire and bigger patch. They will however make a noteworthy change in lateral grip. Anyone who's ever driven a car on pizza cutters and then got into a car on wide tires can notice the difference.
let's also not forget that maximum friction force (for both static and dynamic friction) is dependent upon the "normal load" or weight binding the two surfaces. This is why weight transfer and suspension makes a huge difference. If you ca shift the entire 100% of a vehicles weight/downward force to the rear tires, the amount of friction force is considerably increased. If you're on a high performance track/turn suspension that does not transfer weight well, improvements to the tire setup are going to be nominal.
So once you've maxed out the practical width of the tire, sidewall of the tire (for flex) and compound of a tire, the logical next step is increasing the downward force.
I personally don't like driving a car where you tap the pedal and stair at the tops of buildings. There's plenty of suspension solutions out there that attempt to provide a somewhat changeable suspension setup/solution while trying to launch vs trying to keep a stable ass end going around turns. (changing the dampening, spring rates (or using bags) etc).
Lots of guys focus on tires, but at the end of the day, you can only do so much with the tire, it's really the suspension and weight transfer that has more pronounced effects once you've basically maxxed out what the tire can offer.
Both, would be the best route lol.Overthinking it, probably.
And yes, I agree, at least to a reasonable point that wider is better. Obviously a 2" wide tire wouldn't work out well. But is going from a 275 to a 305 better than going from a Michelin PSS to a Bridgeston RE-71R, both in 275, for example?
Going from a 235/50r18 radial to a 325/30r19 radial did nothing. Slowed me down in fact.it's simple physics
From my road course experience:Overthinking it, probably.
