K4fxd
Call the company who made the rims.Can you tell me which open ended lug nuts I should get ?
you will need open end conical you will need to match your thread sizeI’m on my drive to summit in Ohio. Can you tell me which open ended lug nuts I should get ? I’m getting the ARP studs. What seat style do I need ?
I've had my share of training on fasteners and you are correct. Fabroy, which is one of the largest fastener companies in the world, recommends in stages of 3. 1/3, then 2/3, then full torque.Whatever lb-ft /Nm you tighten your rims to, if you're not doing so already, I believe it's a good idea to do so in stages. For example, typical star pattern, 1/3 or 1/4th of the total each time. Instead of loading one nut/stud all at once with the total force.
I don't have data to support the above. It just seems better to gradually load things.
Good luck with the car. You're on it. Hopefully, you'll have resolution soon.
Well that’s false because LMR says right on their site to use 150 ft/lbs for their SVE wheels for S550.I just got off the phone with Edgar from need for speed performance. He said that 150 pounds is for stock lug nuts on stock wheels he said that you should never go over 105 pounds on aftermarket wheels.
I am also sending him pictures. He said he is very surprised because this typically does not happen. I do have his email if anyone wants to ask him any questions or maybe someone else can call+1-888-714-7467
@K4fxd
The “engineered” amount also factors in a variable margin of all potential errors. As with everything. It’s to stop negligence, stupidity, and mathematical device variables. Not to mention what material actually is the fastener clamping, temperature, load duration etc……Sufficient for normal commuting driving, maybe. Sufficient for how people normally drive mustangs, no. Recommended, no. Warrantable, no.
The M14 stud was literally engineered to run 150 ft/lbs. Run the engineered amount.
Hi,This has happened twice. I don’t understand why my rear studs break off there has to be something going on. They’re torqued to spec I’m 100 percent sure.
Could it be these rims?
Agreed, and to back up your point, GM uses the same 14x1.50 wheel studs on the Camaro… yet factory torque spec is 140 ft/lbs instead of 150…. I’ve been adding a small dab of anti-seize and running 10% under spec (so 140-10%=126 ft/lbs) on a 1059 WHP car that I’ve owned since new. Also have been doing the same practice since I started driving in 1990 and have never had an issue in any form of racing (legal or otherwise). My concern with going right “to spec” is that if your wrench is off a bit and you’re over, that’s how you damage stuff IMO. Ok, old timer rant over LOLThe “engineered” amount also factors in a variable margin of all potential errors. As with everything. It’s to stop negligence, stupidity, and mathematical device variables. Not to mention what material actually is the fastener clamping, temperature, load duration etc……
I would bet MONEY that a torque “spec” of 150lb-ft on a 14mm 10.9 faster has an effective safe clamping range of 120-170lb-ft.
Cool video! Now I want to go on a roadtrip to see !This place is awesome!!!
