The lugs fit fine and yes I get decent thread turns. The car all around have the same lug nuts. I mean what could it be ? I have 315s in the back that’s common. Why is it just happening to me ? I wasn’t even dogging the car I only drive it on weekends. Could it be the rims or maybe something wrong in the suspension that causes this ?Man this would piss me off. The only thing I can think of is you may have to get the extended studs? Hard to tell but do you get decent thread turns on the studs with this setup? Also be sure your lugnuts aren't bottoming out, that would cause them to feel tight but the wheel is actually loose.
I’d pull the wheel and see if the stud hole is cast with an edge cutting into the stud.I believe it’s only happened on this side. I know last time it was this side for sure tho
I have zero wheel hop & have you broken the ARP?Clean everything with carb cleaner including inside of the nuts sometimes. Put on arp studs. If you have wheel hop solve it. Pray.
I too have broken several studs knowing for sure they were installed properly. This is one of several Mustang curses.
