Z_Rocks
- Apr 22, 2014
- S.W. Fla, USA
- Import
Did you try it right in the middle? The max, it will flood it and you will loose power. But I'm surprised you leaned out. What was the AFR when it leaned out? Did it go above 13?So, just played around with meth/water on the new tune. I did 2 pulls in 3rd; 1 with meth at the min setting and 1 at the max setting. Max setting would require a tune for sure. I could actually feel a power loss lol. But, min setting is promising. Timing was up very slightly, A/F was leaned out and my boost psi was actually higher "probably denser air from cooling". I will be testing on the dyno for sure.
