Meth Injection....
Farrdaddy
Ohio
2015 CO/PP
Just looking for some thoughts on it for the s550. Real World horsepower returns.
Thanks
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
It would require custom tuning to make power. Without tuning it will make you lose power.
arieso94z28
New Mexico
I'm adding one on mine. I'll post when I get the results.
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
I lost 20rwhp on the dyno with the meth on the lowest setting. I did back to back test on the same dyno/same day. I wasn't tuned for meth.
arieso94z28
New Mexico
I understand you have to have your car tuned for methanol, which is what I'm going to do. Last car tuned(93 Cobra) with meth on 17psi I gained almost 100rwhp. Helps out a lot!!!!!
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
Oh yeah, if you tune for meth you can gain a lot of power. I had meth injection on a STI and EVO, both gained a lot from it. Most tuners are now very reluctant to tune for it unfortunately. I talked to Lund about it and he refused. I then talked to Ken and he didn't refuse but recommend to just do e85. I just use my setup to reduce the chances of knock when it is extremely hot outside.
arieso94z28
New Mexico
Lund had no problem with me using methanol when I asked them. I'm just waiting to finish the install and then do some datalogs for them.
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
Really? Wtf, I should post his response to me in regards to meth injection. Was it Lund Sr or Jr?
arieso94z28
New Mexico
Greg is my tuner from Lund racing.
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
Jon Jr told me that there was no way he would ever tune for meth injection. Then he attempted to lecture me on how dangerous it was lol. I had to educate him on how this is my third meth setup and if he has ever heard of Snow's safe injection setup.
demas
MustangLand
2014 Mustang 5.0
Whats your controller setup for the meth? @ what psi does it start and at which going full?
ProChargerTECH
Boostville
2015 Mustang(s)
There is an absolutely easy way to tune the cars to make them safe with Meth. And if the pump never comes on, then the tune runs what it would have ran anyway, to keep the car safe.
My .02 on keeping a meth car safe....
1) Run 49/51 mix meth to water.
- Keeps you from having a massive fire in case of a line failure
- Gives you plenty of cooling, and added octane
- Doesn't effect AFR much at all, since its not a "fuel source"
But then again, I don't run crazy amounts of boost over what it would stock.
So if the car was on 7-8 psi on pump gas
I would run 9-10 on the meth (with reduced timing for strait pump)
Then when the Meth turns on, it adds the correct amount of timing.
Even without running massive boost, always have had a great amount of power to be gained that way.... 30-50hp easy. (depending on car, dyno, and temp) Of course people go crazy like these C7 Corvette guys, and make like 700-800-900 (and now 1,200) rwhp with cars living on meth as a fuel source for the power past the 650 mark. Now THAT is a time bomb.
Erik@ProCharger
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
Erik@ProCharger
Snow performance has a safe injectors system that if the system stops injecting for any reason then it can open a bypass valve or wastegate. I have it hooked up to a flow gauge that I mounted in a vent. However, I have ran meth on multiple cars. I had 80k miles on a meth setup on my EVO and it was tuned for it.
ProChargerTECH
Boostville
2015 Mustang(s)
Yes, I would say if you are running highly elevated boost levels that require the meth to be absolutely safe, then the "safe injection" system is a must.
