Whipple help
OrangCrush
2015 Mustang GT Auto 3.55 - X pipe,Roush axleback
I went to go install my Whipple gen 4 upgrade and noticed coolant at bottom of driver side intake. I am assuming it’s the manifold gaskets. Can I pull the lower intake with fuel rails intact? Do I have to have to remove the billet idler plate? I though it was going to be simple but nothing ever is.
AZ_whippleS550
AZ
Douglas
2016 mustang GT
manifold gaskets wouldn't cause a coolant leak check the hose that connects to the top nipple of the coolant elbow mine had a leak there from a clamp that wasn't strong enough
OrangCrush
Thanks for the help. I think it’s coming from the housing under the nipple. Do you think by make sure it’s tight it should be good?
AZ_whippleS550
AZ
Douglas
2016 mustang GT
Change out that clamp on the nipple with a better one that's the style of clamp that leaked on mine. after you do that clean the coolant off and see if the mess comes back.
OrangCrush
Thanks for your help.
96gt4.6
Kansas
2017 GT Premium/A6, 2020 Explorer ST
I had the same problem. The supplied clamp isn't a proper fit and allows a leak at that nipple.
Replace the clamp with a better one like said above, good to go for almost 9k miles and 2 years here. I had to do the same with the Degas bottle end of the hose as well.
OrangCrush
So I got my supercharger off and I can see where I am leaking. Is there a gasket under this?
fmc_smt
Cottonwood , Arizona
O ring
OrangCrush
Replace the gasket or housing also? I only have 13k miles on my car.
fmc_smt
Should be good with a new o ring "gasket".
OrangCrush
Anyone know if there is a certain torque spec for the coolant outlet in pic above?
OrangCrush
