Whipple tune help
SHONOFF15
MI
2015 OW GT
Got the whipple all installed and trying to do the crank relearn and am having some issues. It’s throwing codes P0390 P0394 P0315 P0345 P0349. It stars but runs like shit any ideas??
DavidHuff
Salem,OR
The motor has to be running and operating at normal engine temperature to do the crank relearn.
SHONOFF15
SHONOFF15
MI
2015 OW GT
It’s running like complete shit tho, and I’m nervous AF to hit 4k
Ruiner46
Colorado
2016 CO GT PP
Did you do an oil pump gear install at the same time? If so, it sounds like the timing isn't right or there's a wire harness problem with the camshaft position sensors.
Burkey
Australia
Tyler, upload the video to YouTube and share the link here.
I think that’ll give people a better idea of what they’re looking at.
Cos it sounds HORRIBLE!
SHONOFF15
SHONOFF15
MI
2015 OW GT
I did do the OPG and I’m thinking the timing is off. A friend is bringing over ford PID? to verify it is the timing before we pull it apart.
Svtnos
MI
PT & The Beast
I want to know how the car is supposed to run after you install a whipple and tune ?? Like should it start and run just fine or does it run like shit before you do a crank relearn???
Ruiner46
Colorado
2016 CO GT PP
Mine started right up and idled fine after install. Did the crank relearn after it warmed up a bit idling, then took it for a drive. It shouldn't run like crap unless something is wrong.
DavidHuff
Salem,OR
Mine run fine, but the check engine light was on.I had to do a crank relearn to turn check engine off.
turbofiveoh
Muhrica
Mustang
After uploading the Whipple calibration I had a bit of an idle surge after the first start but other than that the car ran and drove fine.
Almost certain the timing is off. When I did my OPG somebody recommended taking a cell phone picture of the crank gear with the chain installed to make sure the blue link is lined up. I looked from above and the blue link looked like it was aligned with the hash mark on the CG. When I took a picture the blue link was off by a tooth.
SHONOFF15
SHONOFF15
MI
2015 OW GT
Your timing is off. Even if crank relearn is needed, it runs fine. The codes you have are accurate.
Sure was, got it all fixed and now is running like a champ!
[MENTION=13288]Whipple SC[/MENTION] quick question is a pulley from a 2.9 crusher the same as a pulley for the reg 2.9?
