DougS550
As far as the headers, I had my local ford Performance Service center install them due to I was having back issues at that time and needed them installed prior to the winter. Ford did a great job installing them. After the install, I ran the car WOT from a DIG about 20-30 times (on long back roads with no traffic) for hours and I never got a CEL fault. Doesn't mean I will not get one but with the higher quality more expensive cats I feel you have less chances of having issues like CEL faults, Cats clogging etc then with a set of cheap Chinese made LTH.Awesome, thanks Doug. How were those cats? any issues after install?? Do you have blower?
Thanks Anthony
I have a Whipple Stage 2 with Oversized Heat exchanger, Ford Performance Timing chain kit, MMR Hurricanes Oil Pump Assembly, Mishimoto thermostat controlled Oil Cooler ready for my install this winter. This was the reason I upgraded the cats to handle the higher exhaust flow pressures without issues (hopefully).
NOTE: I decided to go with a PD for one reason. I wanted to play in the torque range stop light to stop light, and not play in the horsepower range (Triple digits) and put others at risk from my high speeds. I had to many friends die from rolling the dice and racing the streets. That's just not for me for I know, " O-Shits" do happen and not all of them you walk away from.
