What suspension do you run
Bulldog9
Northern Virginia
2020 Bullitt, 2017 Tundra TRDPRO, 1976 Porsche 912, 1989 Porsche 944S2
I'm running Steeda Sport Springs and their Active Dampers front and rear, Steeda camber plates and rear upper shock mounts, lower front brace and IRS braces with stock sway bars on a 2020 Bullitt (PP1)
Car is very comfortable, mostly composed over washboard, quiet, and tracks like a beast. Great balance for my use. I do want to replace the sway bar bushings as they seem to be glued to the bars and preload the bar and suspension.
I have noticed that on rough roads, pot holes, etc, the Upper mounts on front strut and rear shock do transmit more NVH, but not on tar strips, and normal highway or at speed, just at parking lot speeds.
Mostly happy.
TrackMustang
TrackMustang
SoCal
2021 Mustang GT
Personally I would go with something a little more refined. After having a set of Steedas and then going to the FR track dampers, I would go with the latter or some Billsteins.
FR meaning the Ford Performance Track setup?
Järn
The Motor City
Tony
2019 Mustang GT Premium, Ruby Red, A10, B&O, AE
RAVAGE88
CT
'21 GT Premium
All Steeda. Dual Rate (for Magneride) Springs, F&R Adjustable Sway Bars with Adjustable End Links, Adjustable Camber Plates, Vertical Links, Subframe Bushings (90 Durometer) and Support Bushings, Subframe Alignment Bushings. Also added the Subframe and G Trac Bracing.
MB
TrackMustang
TrackMustang
SoCal
2021 Mustang GT
All Steeda. Dual Rate (for Magneride) Springs, F&R Adjustable Sway Bars with Adjustable End Links, Adjustable Camber Plates, Vertical Links, Subframe Bushings and Support Bushings, Subframe Alignment Bushings (90 Durometer). Also added the Subframe and G Trac Bracing.
MB
Do you still run the stock magneride dampers? I’m trying to see which one I should get and I can’t chose between the one I poster and the FP track setup
RAVAGE88
CT
'21 GT Premium
Yessir, dampers are stock.
MB
TrackMustang
TrackMustang
SoCal
2021 Mustang GT
Andy13186
Pedders coilovers, very happy with them so far. only about 10k miles on them though. Also stop the hop ultimate package but no diff bushings.
trackd
CA
August
19 GT PP2 (SOLD), 73 240Z RB26DETT
How close is FP to PP2 damping, rates, sway bars, etc. So far I'm only running GC camber plates to maximize corner weight and neutralize handling. I'm happy, predictable, balanced.
This Las Vegas track has curbs that you apex on them plus some dips and off-camber tight turns. I'm ok trying to keep up with buddy's modded 700whp ZL1. He buries me on straights of course. I'll be looking at aftermarket later on but not need it yet.
TrackMustang
TrackMustang
SoCal
2021 Mustang GT
Do you run street only or some track? What springs are you running?
Andy13186
Gnatsum21
Fort Lauderdale FL
Former: GT 21 Roush Twister Orange RIP | ECO 2016
This:
