What needs upgraded
Warship2k15
Kissimmee,FL
Kevin
Camaro,C20
Ok I am thinking about buying a new mustang get with the Roush kit on it.
Lebanon Ford or any other one that offers a good deal on this package.
What would need upgraded if someone hypothetically added some drag radials.
Would the trans live at these levels?What about the Rearend and half shafts?
Driveshaft going to be ok??
What times would someone be able to run??
This would be my first mustang since the 80s so any advice would be helpful.
Warship2k15
Kissimmee,FL
Kevin
Camaro,C20
I guess I should be more specific it’s the Roush 750 hp supercharger kit.
EFI
Masshole central
5.Br0
Depends on how you launch it. If you slip the clutch and launch relatively normally, the trans and rear end should fine fine, the weakest link being the half shafts. Drop the clutch at 5000rpm and neither of those will last long.
The times depends on how you launch and shift, anywhere from mid 12s to mid 10s.
Warship2k15
Kissimmee,FL
Kevin
Camaro,C20
Ok I guess I left out some info.
It would be an automatic transmission.
EFI
Masshole central
5.Br0
Still depends on how you launch it that will dictate how long things will last. I would at the very least do halfshafts if you want to use the car to its potential, the rest should be ok.
NGOT8R
Adrian
2019 Bullitt
Manual or auto? The consensus is bias ply for a manual tranny and drag radial for an auto tranny. I’ve read that the factory driveshaft has held up well in cars making north of 800 rwhp. Half shafts are very good insurance. At that power level, I’m guessing you’d run low 10’s in the 1/4. I have a friend who has an Edelbrock supercharged ‘19 GT making 880 rwhp and he’s gone 9.80’s at 139-140 mph. He has an auto tranny.
Warship2k15
Kissimmee,FL
Kevin
Camaro,C20
Thanks for the response
It’s an automatic.
Also what half shafts are you recommending??
NGOT8R
Adrian
2019 Bullitt
It’s an automatic.
I’ll be going with G-Force. That’s what my friend runs in his car, along with their driveshaft. There seem to be way too many horror stories about DSS half shaft failures and them taking weeks upon weeks to perform warranty work. It appears that G-Force has got their act together.
vanquishvzla
Jacksonville - FL
2015 Mustang GT 50th anniversary
if you are buying new, with factory from the dealership, launch and shit like you hate it! if it breaks.... warranty!
Zelek
Hutto, TX
2021 Mustang Mach 1
I went over this same thing when I bought the On3 single turbo kit:
Must haves:
Clutch (Manual only)
Fuel System (BAP can be used but I like my fuel pumps to live)
OPG/CS (debatable but insurance is nice)
Tires
Suspension
Can live without:
Half shafts (Unless you're hard launching all the time)
Driveshaft
Transmission upgrades (Unless above 700-750+ whp)
NGOT8R
Adrian
2019 Bullitt
Must haves:
Tires
Suspension
Can live without:
Driveshaft
I like these lists and how they’re broken down. May I ask a question about BAP? You say they can be used, but you like your pumps to live. Are you suggesting that a BAP (one that increases voltage all of the time)may cause early pump failure? What about one that ramps up voltage beginning only at 50% throttle and continually increases in voltage until 75% throttle, where it then reaches the max set voltage of either 18V or 22V?
Zelek
Hutto, TX
2021 Mustang Mach 1
Anything that increases the amps to the fuel pump like the VMP BAP for example can cause more wear on your fuel pump because it's always running. Something like the JMS BAP can prolong it based on what you're mentioning above with voltage based on throttle.
The Rodeheaver's fuel system I'm putting in does exactly that. It runs at stock levels and when you mash the throttle, the pumps get the extra juice they need. Remains very OEM with the connections and GT350 pumps. While cruising the pumps remain at stock voltage. Many fuel systems keep these pumps running with extra power all of the time and that's why you see pump failures. Some of these cars also need the pumps running full time to keep up. There's going to be trade offs no matter what way you look at it.
Soulja4187
Greenacres, FL
David
2021 Mustang GT Premium & 2025 Explorer ST
Besides the half shafts I would also recommend the oil pump gears and then stiffen the rear so your wheel hops don't destroy your differential.
