kb19
Mewant leather steering wheel cover. Custom ordered green with green stitching (camera lighting makes it look real) to match the EG exterior. Now girth is as thick as current BMW M steering wheels.
Had a chance to run the south oval/road course at NHMS in Loudon. On the third lap I ran over on track debris and blew the left rear tire on the straight at over 100 mph. There was no way the inflator goo would patch the large gash in the tire. Luckily I only live 30 min away and my wonderful bride was willing to bring my spare set of tires/rims to my rescue.Yes. A spare tire and jack. Auto Authority has a wheel that will fit over the the large 6 piston Brembos, yet will still fit in the trunk wheel well.
I have had too many flat tires in the wrong place and at the wrong time to be with out a spare.
I spent close to 2 hours stranded waiting for a hook with my 2013 Boss when a piece of metal slit the rear tire.
The supplied tire goo and compressor did nothing but make a big mess.
Never again.
Hmm, I'll have to see how long mine last. Saving them exclusively for the track. Well, I put 100 street miles on them.Chin track days at Mid Ohio. I did the two day Monday and Tuesday and wound up burning 90 gallons of E85. That equates to about 5 1/2 to 6 hours of actual on track time. I can now tell you just exactly how long it takes to burn through a set of cup2’s!!
It didn’t seem like I did need the flap since I’m rocksolid in the corners. I have Steeda’s adjustable sway bars with a Steeda dual rate magna ride Springs and the magna ride controller. Stop the hop kit road course edition, and camber arms and plates. I am at the stiffest on the rear bar and the second from the softest on the front bar. She rotates well but I would prefer her to be a bit more loose. I am running what Steeda recommends for track settings -3° in the front and -2° in the back for Camber about 2 1/2 to 3° tow in for the rear and about a half a degree toe out on the front tires. It must be working well because I had lots of guys coming up to ask me what kind of tire I was running and all about the car.Hmm, I'll have to see how long mine last. Saving them exclusively for the track. Well, I put 100 street miles on them.
So you don't need the Gurney flap on at Mid Ohio?
Good to know. I'm planning on keeping my car stock for a while. I have the Gurney flap off for street driving but plan to run it on track. Will see how it goes. The Manual does state it might not be needed for tracks with corners that are less than 70mph.It didn’t seem like I did need the flap since I’m rocksolid in the corners. I have Steeda’s adjustable sway bars with a Steeda dual rate magna ride Springs and the magna ride controller. Stop the hop kit road course edition, and camber arms and plates. I am at the stiffest on the rear bar and the second from the softest on the front bar. She rotates well but I would prefer her to be a bit more loose. I am running what Steeda recommends for track settings -3° in the front and -2° in the back for Camber about 2 1/2 to 3° tow in for the rear and about a half a degree toe out on the front tires. It must be working well because I had lots of guys coming up to ask me what kind of tire I was running and all about the car.
If you want a PPF specific ceramic coating, there are a few options out there: Carpro CQuartz Skin, Gtechniq Halo and Gyeon Q2 PPF. Just thought I’d mention it if you’re looking for something that lasts longer than a spray sealant.After receiving Skye, I had the car covered in PPF. I've been grateful for the coverage and how that project worked out.
While familiar with traditional waxes, I was not educated in other products, like user-applied paint or PPF sealers. I'd started off with several Chemical Guys products and selected Jet Seal to seal the PPF.
Jet Seal applied easily and produced a good finish. No issues. Unfortunately, like so many CG products, its staying power was less than desired. After only two or three washes with a pH neutral soap, the product dropped-off markedly.
I began to question if I was applying the product correctly. By the label, I was. I witnessed like results on a non-PPF vehicle. So I pulled back, began looking for 1) a better product, 2) one that was designed not only to be PPF-friendly, but to specifically protect PPF.
XPEL does make a PPF sealer and I studied that product. I then began looking into Gyeon's offering. What I liked about Gyeon is they not only offer a PPF sealer, but a PPF wash. I bought and have been using both for the last few weeks.
https://gyeonquartzusa.com/product/ppf-wash/
https://gyeonusa.com/products/q2m-ppf-maintain
Gyeon PPF Wash is a decontaminating wash. One of the references I found advised that, being a mild dcon soap, it should be used every six to eight weeks or less. Following the instructions, I used the soap without issue. I did not experience any paint "bleeding" like you might see in other decon examples. But I did notice during the rinse that the paint/PPF appeared different. Water and light seemed to reflect greater, being more luminescent. In ways that told me the paint/PPF had been deconned and/or the product was having a positive effect.
I later used Gyeon PPF Maintain. PPF maintain is a sealer. The instructions are simple: 1) shake the bottle, 2)spray a modest amount on a clean microfiber towel, 3) rub onto the PPF, 4) keep rubbing. The product will dry and "slick" up. That's it. No hazing. No residue. No nothing. Just slick.
And after a few weeks and a few washes, while the CG product would have already faded, the Gyeon product has yet to do so. The Gyeon product is wearing better, protecting better and appearing better, longer.
One CG product I am still using is their Meticulous Matte Wash or soap. I'd been concerned of some soaps and how they'd impact the matte decal on the hood. I also wanted something that was simple soap. No image enhancers, waxes, silicones or other additives. When not using the PPF Wash, I'll continue to use the Meticulous Matte soap. But as I run out of that product, I will study and consider others reviewed by Members here.
Thank You. I agree.If you want a PPF specific ceramic coating, there are a few options out there: Carpro CQuartz Skin, Gtechniq Halo and Gyeon Q2 PPF. Just thought I’d mention it if you’re looking for something that lasts longer than a spray sealant.
Totally get it. Happy to share what I did as far as garage setup when I did my coating if you’re interested.Thank You. I agree.
I've looked into two of those products. I believe in the items you mentioned. I'm not sure I can provide the best setting to apply them though. I'd like to be in a clean, stable environment for a solid 24-36 hours. Fall might be the best time.
Maybe make a post (in the appropriate forum area) as I could see this being helpful for many people.Totally get it . Happy to share what I did as far as garage setup when I did my coating if you’re interested.
Yup! It was a very short jaunt and the E85 tune effect was also apparent. I did indeed search and bookmark some used M1 in the general DC-Pittsburgh vicinity. Now I just need to convince him to go to PittRace and we can drive each other's cars.Let @shogun32 drive it he might have even liked it!
^. I think posting any insight when you have time would be great. Thanks again.Maybe make a post (in the appropriate forum area) as I could see this being helpful for many people.
