VicRattlehead
- Jul 16, 2015
- Route66Raceway
- 2015 RS1 Roush EcoBoost
Where are we with this?
I have the snow stage 3 meth kit on mine. No dyno numbers as of yet since Adam is still tweaking it. But, the car does feel wayyyy faster!Where are we with this?
i agree 100% with everything said. I ran 100% meth in my turbo eclipse, nothing like 32psi on 93There is another thread that I commented in awhile back.
I'm running the FFTEC 7670 turbo kit on 91 piss.
I installed an aem progressive meth kit on the charge pipe BEFORE the intercooler.
I picked up around 40-50whp and a massive drop in charge temps on the road course. Anthony at FFTEC did a great job dialing it in.
Since the AEM kit is boost based you can control when it kicks in and when it gives you full injection.
I have a 2.5 gallon tank in the trunk and the pump is next to the tire pump.
Then the line is run along the OEM fuel lines under the plastic protective panel.
I would highly recommend it.
In my opinion run straight meth over a mix. The 50/50 mix was made for two purposes.
1 because you can't ship straight meth on a plane. 2 because it is not as flammable.
Realistically as long as you route the lines like an intelligent human being you'll be ok.
I've seen some idiots run it near the turbo on other cars, in that case natural selection will take its course.
Mine comes up on the firewall on the driver side. Then along the frame rail, along the fan shroud and into the charge pipe.
I would do this over e85 any day. Far more convenient and helps clean the intake mani.
I fully intend on running meth on the EB as well. I talked to Adam, you're probably one of the ones he said he was working with. Keep me up on what happens. Any tips tricks and whatever. Let me knowI have the snow stage 3 meth kit on mine. No dyno numbers as of yet since Adam is still tweaking it. But, the car does feel wayyyy faster!
Where are you getting 100% meth at? Nice install btw!!!![]()
Here you go, I have the controller mounted above my right knee.
There's a gas station about 30 min away that sells it by the gallon.Where are you getting 100% meth at? Nice install btw!!!
Where is your tank installed?![]()
2 injection points. A power nozzle at 2 inches and regular nozzle at 10.
just curious adam I know when I hit you up about buying a meth kit you steered me away from it what changed? Can you run meth along with e30 or can it only be ran/tuned for straight 93?Justin's car is responding very well to the meth, I want to tune more cars on meth haha.
