Meth injection help and basics?
z6cyl
Colorado
Zach
2017 Mustang GT Base, MT-82, Ruby Red
Hi all,
I'm looking into meth injection for sick gainz, but never used such a system and have a few questions?
1. Do any kits specific to the EBM currently exist, if so where?
1.5. Are these kits easy to install?
2. What HP gains can be expected when using meth injection on an otherwise stock EBM?
3. Where exactly does it inject at?
4. Would meth injection help to reduce carbon buildup on the top of valves?
5. Also, should I run colder plugs with a meth kit (or should I just run colder plugs in any case?)
S550SVO
maryland
2015 ecoboost mustang, 86 mercury capri,86 svo
Snow performance and aquamist both have kits for the ecoboost. The kits are easy to install.
Meth injection itself does not provide horsepower. It let's you tune the car more aggressively to release untapped hp.
As far as where it injects at ,can be before the throttle body ,or after .
Yes it will reduce the carbon build up on the valves.
I personally think the car should have a colder plug even in stock trim .
z6cyl
Colorado
Zach
Thanks for your reply.
Of course on the tune part. ;)
If I inject in the cold side of the charge piping, that is before the throttle body, yes?
As it relates to where to inject at, do you have to drill into the charge piping or the ??? (other place it can be put)? Or do the kits include valves for this?
z6cyl
Colorado
Zach
Thanks Brad, good observation.
I'm reading that the flash point of meth/water 50% is 86 degrees F. Is this a concern?
Tune+
St. Paul, MN
www.facebook.com
Adam
2015 Ecoboost Mustang Automatic
Hi all,
1 - I recommend snow
1.5 - They aren't too bad, about as hard as putting on an intercooler
2 - About 25-40 additional horsepower with a proper tune. I do offer Meth tuning.
3 - I recommend about 10 inches from the throttle body on the charge pipe. It is best to have an aftermarket pipe. Doing it with a throttle body plate is easy, but it isn't ideal as it injects on the backside of the throttle blade
4 - Yes it will, along with some of the cam tuning development I am in the middle of, it will REALLY help with carbon buildup
5 - I recommend Denso ITV22's or NGK 6510's gapped at .026"
Let me know if you have anymore questions.
z6cyl
Colorado
Zach
Can you elaborate on the cam tuning? That's just total software right, not different cams or anything?
Tune+
St. Paul, MN
www.facebook.com
Adam
