Velossa Tech Design - BIG MOUTH development
Status
Not open for further replies.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Just to clarify, with a stock grille this requires opening up the honeycomb to get the necessary flow for this to work to its potential, correct?
VelossaTech
VelossaTech
www.velossatechdesign.com
Ford Focus ST
That is correct, maximum flow through the ram air duct when you remove the hex flats.
BmacIL
Enginerd
Naperville, IL
I'm a tiny amount concerned about snow ingestion with opening that up all the way. Guess we'll have to see.
BmacIL
Enginerd
Naperville, IL
And rain, don't want my panel filter getting all wet
That shouldn't really be a problem. You won't hydrolock an engine unless you basically submerge the filter. Snow, on the other hand, packs up and will cause significant restriction.
stoli
Fat Guy Racing
Lakeland, FL
'15 Black GT/PP
The panel filter is at the top of the box. So you would need to ingest enough snow or water to fill the tube coming in, the resonator in the first segment of tube, then the bottom of the intake box... Basically you would need to dip the grille of the car in a lake. In such a case I think you should worry about evacuating out of the car, and not the panel filter getting wet. :)
Oh, and the filling would have to take place quicker than the water drains out the bottom.
BmacIL
Enginerd
Naperville, IL
See my post above. I am only concerned with it getting packed up with snow and severely restricting airflow. It happens on heavy trucks all the time.
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
I'm thinking that if the snow is that bad it packs up your intake track it won't make any difference if there's a velocity stack there.
rozay
South Florida, Broward
2015 PQ 5.0 MT
If it snows that bad you shouldn't drive that beauty anyways
BmacIL
Enginerd
Naperville, IL
No but if you open up all the grille honeycomb flats to take advantage of the big mouth, you could have a problem. It's unlikely, but could happen.
Mine is a DD so not driving in the winter isn't an option.
stoli
Fat Guy Racing
Lakeland, FL
'15 Black GT/PP
I don't think this seals tightly into the intake path, but I can see your concern. Velossa Tech should be able to better address it.
VelossaTech
VelossaTech
Ford Focus ST
i havent driven it in the heavy snow as I live in florida, so I cant guarantee. What I can say is I find that highly unlikely, you would need to be going 100 mph and WOT to suck in enough snow to really cause a problem. Even then it would eventually melt out since it is hot near the airbox.
I would say you will be ok.
BmacIL
Enginerd
Naperville, IL
Who says I wouldn't be? :D
Kidding of course. It's probably fine, I just know these cars were tested for that and I can't be sure if the grille is blocked off so much for drag benefits or snow intrusion or both. Probably the former. That duct should stay warm enough, and if not, a few minutes idling on the side of the road will melt it :).
Zerobar78
Phoenix
2015 CO GT, PP
Mine showed up today:
It's a solid piece, really like it. Hope to get it installed this weekend.
Souldriver
NY
2016 - Guard GT Prem. PP
i would like to see how this works with the RTR grille, i think those are much more open and do not have anything in the "triangles". though those triangles are a different shape.
Status
