stangs-R-me
- Jan 14, 2014
- Northeast Wisconsin
- Doug
- 1969 GT & 2016 EB Mustangs
First MOD I did back when I got the car in May 2016 was put on a UPR Dual Valve Catch Can ... car had less than 30 miles on it and 6.5 months later it has around 12k miles.
UPR Checks are correctly oriented per their diagram (checked more than once) ... captured about 1 oz. after the first 1000 miles and has captured about 12~15 oz. total to date.
Problem is I smell crankcase fumes INSIDE the car all the time when sitting at stop lights and can smell it when shut off in the garage or when I'm under the hood working on stuff. The odor is strongest right around the DV CC.
Back when car was two weeks old, I thought I'd seen smoke out the tail pipes so I figured it could be actually burning oil so I posted this thread ...
http://www.mustang6g.com/forums/showthread.php?t=56270
I never could actually smell anything out the tailpipes though, but bought it into the dealer to have them check it out and they narrowed it down to the DV CC which made me feel pretty dumb bringing it in.
I then noticed the (3) 1/4" NPT nipples in the can appeared to have no thread sealer on them so I added good mil-spec teflon tape. As there is not a lot of thread engagement I later changed the tape out for Permatex 2 ... neither made a difference as the smell is still there.
I've inspected the upper O-Ring a couple of times (last time was today) and it appears to be fine, and the lower o-ring and drain plug have got to be fine as they are both below "liquid level" and it has always been dry as a bone down there.
So I've got to have a vapor leak at one of the 3 nipples, the upper o-ring or one of the hoses.
Only way I can think to test all of this is to remove complete system off of car, get 3 extra nipples to fit in the hose ends with FM pipe caps added to 2 of them and a shop air QD on the third. Then submerge in a tub of water and apply a few pounds of shop air pressure to find the leak !!
I strongly believe in catch cans especially on a direct injected engine, so removing the DVCC for a week to to see if smell is completely gone is something I really don't want to do. I also really believe the DV design is superior to all others, so I'm not all that keen on dropping the cash on a different system either.
UPR ... can I get three of these special nipples to do the test I mention above ??
Kit was ordered NEW from Lethal Performance in Feb 2016.
Also, what size and type O-Ring do you use on the can ends ... I measured 2.25" I.D. / 2.37" OD which would be a -035, guessing 70 Durometer Buna-N but want to know for sure.
Doug
Doug
