Applies to all 2018-2019 5.0 S550’s.
Issue:
Some 2018-2019 F-150 and Mustang vehicles equipped with a 5.0L engine built on or before 30-Apr- 2019 may exhibit a chirping type noise from the upper engine front cover area at warm or hot idle. This noise may sound similar to a front engine accessory drive (FEAD) chirp noise. This may be due to the primary timing chain tensioner oil pressure relief valve. To correct the condition, follow the Service Procedure steps to replace the primary timing chain tensioners.
See attached pdf for complete TSB content.
Issue:
