Triple 7 Performance Grill Lights?
Deerfield Beach, FL
www.tripleseven-na.com
Jeff
18' GT
Would it really be that hard to mount Diode Dynamics lights to the factory fog inserts?
I'm not going to stand here and say its rocket science to make these brackets for the lights but it took us a few months of testing and getting proper tight fitment with the lights and the upper grill. If you could replicate it and make a better version by all means more power too you I'd love to see a better version if it can exist while we try to keep making ours better.
RobZ71LM7
Louisville, KY
Rob
2021 Mach 1, 2019 F-150
Gotcha. I am by no means denigrating your efforts and glad someone brought it to market which should show there is a market. When things slow down it's on my list of things to do...these are the kind of things I enjoy.
19fury
California
19 mustang
You could easily use your stock grill light cover as templates and use a Tupperware lid or plexiglass Cut with a jigsaw or Dremel and Mack a few extra . so you can experiment with different light configurations.
MACHtobers Very Own
Hampton Roads, Virginia
2022 Mustang MACH 1
What's up with those Mach 1 front splitters/canards listed on the website though!!!!
19fury
California
19 mustang
777 has a different sweet looking bottom grill for extra breakcooling ,you could actually even add fog lights in those holes as well . The middle is fully open as well , I went with this option I like. It But decided to not leave the middle section open and added center piece. neighbors cats, like to get into the front bumper cover pretty easily. Took care of that problem.
MACHtobers Very Own
2022 Mustang MACH 1
I saw that but I thought it was listed as only working for their front end versus oem.
19fury
California
19 mustang
That’s a shame I wonder why? It’s a really nice upgrade.777 would probably sell a lot more of them. If they did fit the stock. Mach-1
Im not sure what all the differences are
The 777 bumper fit better then my stock 19 bumper ,was even able to use the stock turn signal or super nice diode one that are out . Also the stock gt belly pan lined up well the 777 bumper.
Deerfield Beach, FL
Jeff
18' GT
Our Handling lip is the secondary chin spoiler for Mach1's, we are working on chassis mounted splitters for the cars as well. The Dive planes we prototyped and are waiting for our first production sets to come in, they will be made from carbon and will fit both OEM and our Mach1 front fascia
Fishtales
Boston, MA USA
2001 Harley, 1964 Volkswagen Beetle, 2016 Toyota Avalon
It's a good revision. I like the fact that mechanically it is a snap in.
I'd suggest the following for improvement:
- A harness that is plug compatible to the parking lights. No cutting or splicing into factory wiring harness. I doubt there will be many folks looking for directional flashing, so make it a simple two wire connection to make it cleaner.
- A control run in the harness to enable a simple switch to be added in the vehicle for independent control. Provide the run and a switch.
- Determine the switch and mount location in the vehicle. I'm sure folks can assist here. Make switch connection plug compatible. If by chance someone does not want the switch, provide instructions to cut the loop and connect the wires - could provide the connector as well.
Customer responsible for mount (location if preferred location not used, drilling and mounting.
traxiii
Mustang is my middle name
Nor Cal
Bill
Yep, I was thinking that would make a great place to put fogs in too.
traxiii
Nor Cal
Bill
There is room for a couple switches to the left of the cigarette lighter 12v outlet.
Weeee
Utah
Tom
Mach 1, Mach E GT
TJ Smith in the 2021+ Mustang Mach1 Nation facebook group used a Ford Mustang fog light wiring harness.
"Finally me and my brother got around to install the 777 Performance GTE Fog Lights using the Starkey Fog Light wiring kit with OEM fog switch. I used the 15-17 kit so I would have the H11 fog light connectors and got the H11 TO DEUTSCH adapters to connect to the Diode Dynamic fog lights that 777 uses.
https://www.starkey-products.com/foglight-wiring-adapters...
https://www.starkey-products.com/mustang-fog-light-wiring...
https://www.tripleseven-na.com/.../777performance-gte-lights
I also added the Opt-7 LED Arrow Turn Signals with Switchback Smoked
https://www.opt-7.com/2015-2017-mustang-led-turn-signals.../"
Fishtales
Boston, MA USA
That is pretty nice. Looks like we have a complete solution.
traxiii
Nor Cal
Bill
Pictures Please!
Weeee
Utah
Tom
Mach 1, Mach E GT
TJ didn't post any photos of the install. He did show pictures of the finished product and it would appear that 777 has listened to the community and has revised the covers (it's got depth now!) and have hidden the fasteners by coloring them black.
