Trickle Charger during hibernation?
Cleesj
Michigan
Jake
2022 Mustang GT Premium PP 401a 6MT MP
In case anyone is interested, the Ctek battery tender is on sale for a pretty reasonable price on amazon. :thumbsup:
skinnyb
Knoxville TN
Alex
21 Mach 1. FJG, Tremec, ESS G3X
I have a Noco Genius 2D mounted under the hood of my car. Wired to a ground on the strut tower and the hot is ran to the last screw in terminal on the fuse box. Tucked in beside the strut tower and zip tied to the wiring harness there for safe keeping while driving. It does have a very short AC cord so I run my extension cord up and thru the crack of the hood and headlight and plug in then tuck the plug in before shutting the hood. Works really good, easy to unplug when I want to go for a drive. I try to take mine out at least once a week, I hope to continue to do so thru the winter if I have a fairly good weather day since I installed some All Season tires.
TonyNJ
Northern NJ
www.instagram.com
Tony
I must have posted in another thread revolving around this because I don't see it here. I typo'd the name, it's IntelliCharge, and not IntelliCharger, my mistake. It's part of the CarCapsule that I have for the Mach to park in during extended times of not being driven. See the links above. This is the only picture I have of it at the moment.
Being in Tennessee, I wholly agree!
I would definitely end up running that thing over eventually. Fortunately my wire is dropped across my windshield cowl area so I'm reminded to unplug it.
Rapid Red
Woodstock GA
Greg
FYI for the inquiring minds, the Bluetooth monitor & app WD Pro mentioned.
Will work with any battery & charger it's a stand-alone device that has nothing to do with the CTEK chargers.
Prodigal
OKC
2021 Mach 1
Installed a CTEK yesterday. Pretty easy once I figured with post in the fuse block to use.
JamieWS6
Jamie
06 Mustang GT, 13 Boss 302, 22 Mach 1 coming
Is CTEK the best trickle charger? I've used the Battery Tinder but they're made in China and not sure I fully trust them now.
Prodigal
OKC
2021 Mach 1
So is the CTEK but it’s high quality. Lamborghini and other similar manufacturers rebrand CTEK chargers and include them with their vehicles. The reviews are very good. No regrets here.
Rapid Red
Woodstock GA
Greg
They are still a good, solid & reliable charger, have 2 taking care of my HotRods.
04mazdaspeed
Illinois
2022 Mustang Mach 1
I have 6 NOCO genius 2amp tenders. They all work as designed and small form factor. I do have the quick disconnects on the battery since I always plug mine in when Im not driving it.
JamieWS6
Jamie
Thanks. I just purchased two. I'm sure I will like them, if so I will be getting at least a couple more. 🙂
swoop1156
22 Mach HP, 22 Raptor 37PP, 22 Cayenne Turbo SE
It's not in it's permanent spot, although I do like how I have the cord ran through the fender vent and up behind the headlight so there's nothing draped on top of the side of the car.
DougS550
Fishers, Indiana
Doug
I have a 7A CTEK (MXS 7.0) and yes, that's the profile in my charger :like:
I drop the charging cable through the engine bay and sit the charger under the car connected with a IP54 socket, once connected I push it arms length under the car.
It's in the CTEK rubber bumper and I have put rubber feet on its base so if any water puddles, it won't sit directly in the water :like:
I've washed (including jet wash) the car multiple times whilst it's been on charge with no issue :like:
WD :like:
This is my Charging or Winter storage trickle/Maintainer charging set up.
plresultsman
Milwaukee, WI
en.wikipedia.org
16 White GT Vert GT PP Roush Stg1 M'flow ctbck
Battery tender
I second this one. Used last winter and again this one. Works fine. Only wish the bit that connects to battery was about four feet longer, to eliminate opening hood to hook up.
Lou-Q
Florida Keys
Louis
39 Cadillac Coupe, 67 Cadillac convertible, 67 Corvette roadster, 2015 Mustang Gt 50th anniversary, 2020 Shelby GT500 (on order), 1990, 1999, 2011, 2019 F250 P/Us
Does anyone use the Harbor Freight maintainer? I've been using theirs at our farm for all our tractors without any issues for years. It extends the battery life to around seven years or more.
Lou
